Some important info on the brackets ...
There is a difference between 3D and 5D brackets. 3D is lower than 5D.
So if you got 5d bracket, in order to install it in 3D Stilo, you need to cut the bracket and make it shorter with approx. 3.1cm. and then weld it.
If you are installing a 3D bracket in 5D Stilo, you need to extend the bracket with approx. 3.1cm. (like in mine case).
Off course you could always get a new bracket, but in Bulgaria (where I'm from
