Step 2. Fitting Instructions
Ok, here’s your fitting instructions, you need two small flatbed screwdrivers and less than half an hour of your time.
Fitting is quite simple, pop out the tray in the central console with some flat blade screwdrivers.
Fit the orange casing through the new console trim making sure you align the cap to the right orientation
Fit the 12v socket through the orange casing (it will only go in one way)
Connect the wiring loom connector to the socket and test with a suitable appliance (sat nav). Remember the socket only has power while the ignition is switch on.
Once you have confirmed power is getting to the socket switch off and snap the trim in to place.
Job done.
Cheers Sean (50p)
