Refill with Oil
It's easier to use a funnel with a flexible filler pipe to refill the oil. When you have added the required amount (I used 2 litres) then replace the breather valve (be careful with the tightening), refit the air filter box, close the bonnet and carefully lower the vehicle off its stands and jack to the ground.
