The FIAT Forum
  • Forums
    New posts Featured threads Search forums Members list Members map
  • Guides
    New guides Latest reviews Series list Search guides
  • Downloads
    Latest reviews Search downloads
  • Garage
    New vehicles Latest content Latest updates Latest reviews
    Series list Search garage
  • ePER
  • Events
    Monthly Weekly Agenda Archive
  • Gallery
    New media New comments Search media
  • Classifieds
    New listings
  • Directory
    New businesses Latest content Latest reviews
    Brands Search reviews
  • Shop
    Latest reviews Search products
Log in Register
What's new Search
Search
By:
Advanced search…
  • New guides
  • Latest reviews
  • Series list
  • Search guides
Menu
Log in
Register
Install the app
  • Guides
  • FIAT Cars
You should upgrade or use an alternative browser.
500X Front brake pads and rotor
  • Author arekp
  • Publish date Jul 31, 2021
  • Article read time 1 min read
Guide Gallery Discussion
Brembo pads and rotor
Guide
View attachment 500X_front brake pad rotor removal.pdf
Share:
Facebook X (Twitter) Reddit Pinterest Tumblr WhatsApp Email Share Link
Guide information
Author
arekp
Article read time
1 min read
Views
1,953
Difficulty rating
2.00 star(s)
Join the discussion
Downloads
  • 500X_front brake pad rotor removal.pdf
More in FIAT Cars
  • The Panda Nut
    Panda 2012+ Cleaning the VVT solenoid actuator 1.2
    Poor power? VVT actuator is reponsible for altering the valve timing. It has a number of mesh...
  • A
    500X 1.4L multiair alternator clutch pulley replacement without removing alternator
    There is a good video to explain how the pulley works, but he shows a reverse thread. In the...
  • wingless
    500 (Classic) Fitting front seatbelts to a 1968 Fiat 500L
    My 1968 Fiat 500L never had seatbelts. It is sooo weird driving a vehicle w/o seatbelts (even...
  • GrandePunto PL
    Grande Punto LeftHandDrive, the OBD2 port location change.
    LHD (left hand drive) Grande has a problem with OBD2 port access (especially during extensive...
  • V
    Panda 2012+ Number Plate Lamp
    The basics of accessing the bulb in a Hatch mounted Panda lamp Turn on lights to see which need...
More from arekp
  • A
    500X 500X MultiAir oil strainer replacement
    1. undo 10mm bolt 2. pull out wire harness, it is tightly jammed in so you have to work itover...
  • A
    500X 1.4L MultiAir spark plug replacement
    1. undo 10mm bolts holding beauty cover 2. label coil packs (1 -> 4 left to right) 3. undo...
  • A
    500X 1.4L multi air coolant reservoir replacement
    I needed to replace the coolant reservoir as it was starting to leak at the seam and every few...
  • A
    500X 1.4L MultiAir Timing Belt and water pump replacement
    This PDF has photos for all steps If not done correctly, you will damage the engine at your own...
  • A
    500X 1.4L 500X Pop serpentine belt replacement
    1. pull off the hub cap, there is a notch under the "500" for flat head screwdriver 2. loosen...
Share this article
  • Guides
  • FIAT Cars
  • The FIAT Forum
    fiatforum @fiatforum
  • About The FIAT Forum
    The internet's #1 online community and oracle for all things FIAT since 2002 - if we don't have the answer, no-one does! Ask questions in the forums, fix common issues using our helpful guides, upload your photos to the gallery or buy and sell with the online classifieds.
  • FIAT Forum
    • Forums
    • Gallery
    • Downloads
    • Search
    • RSS RSS
  • Members
    • Log in
    • Register
  • Site Help
    • Contact us
    • Advertising
    • Terms and rules
    • Privacy policy
    • Help
Community platform by XenForo® © 2010-2024 XenForo Ltd.
Proudly hosted with by endrop.
