Wiring from the Engine Node
Only read this if you’re sure you can’t find the brown connector in the battery box!
What you’ll need to do for this is to take the feed for the 4 cruise feeds (see last section) directly from the engine node.
Once located, you will see the following connector:
The following wires must be connected then fed to the cruise control stalk (see the previous or next page for stalk wiring):
M10-A (Engine Node) ------> H7 (Cruise Control Stalk)
1.2 16V
Pin 58 ------> Pin 4
Pin 41 ------> Pin 1
Pin 08 ------> Pin 5
Pin 09 ------> Pin 6
1.6 16V
Pin 33 ------> Pin 4
Pin 17 ------> Pin 1
Pin 41 ------> Pin 5
Pin 21 ------> Pin 6
1.8 16V
Pin 57 ------> Pin 4
Pin 23 ------> Pin 1
Pin 53 ------> Pin 5
Pin 31 ------> Pin 6
2.4 20V
Pin 10 ------> Pin 4
Pin 42 ------> Pin 1
Pin 58 ------> Pin 5
Pin 43 ------> Pin 6
1.9 JTD
Pin 53 ------> Pin 4
Pin 55 ------> Pin 1
Pin 56 ------> Pin 5
Pin 57 ------> Pin 6
Then, proceed as with the previous page to get the wire into the car, then hook up the +12V feed etc etc. . .
