Old 18-07-2019   #1
nikrox has donated!
1.4 Gearbox Ask
Just towed my friends car home. She was reversing when ,without warning she felt something go 'ping?' and hey presto no gears.
No side to side movement in the gear lever,no friction going from first to second...and its stuck in reverse gear.
Clutch res is full,no leaks anywhere and the clutch pedal feels normal.
Slave cylinder is dry too..not a lot of movement in the arm tho..but then again I dont know how much there should be.
I took the gear lever cover off,tried to engage reverse and theres nothing connecting the bush that slides up the pillar of the lever.Some plastic bit did fall out.
Any one got any ideas?..please..
nikrox is offline Reply With Quote Quote
Old 18-07-2019   #2
Re: 1.4 Gearbox Ask
Sounds like a cable has snapped or come disconnect. Check under the bonnet for movement when moving the gear lever. The cable at the back needs to be in the middle position to get neutral,you can do this by hand,so you can move the car(by pushing it)?
Thanks nikrox thanked for this post
Likes nikrox liked this post
multipete is offline Reply With Quote Quote
Old 19-07-2019   #3
nikrox has donated!
Re: 1.4 Gearbox Ask
Thanks for the reply Pete. It was indeed a snapped cable.
46 for a genuine cable,which was 20 cheaper than an aftermarket one.
And it would rain the day Im on my back under a car wouldnt it...
Old 19-07-2019   #4
Belgium
Re: 1.4 Gearbox Ask
Quote Originally Posted by nikrox View Post
It will probably indeed ...
Do you remember there is a 'zeroing' procedure to adjust the cables ? I don't think it's on all kinds of GB but maybe yours has it ...
Cheers, Bernie
Old 19-07-2019   #5
nikrox has donated!
Re: 1.4 Gearbox Ask
I looked at the polish video referenced in here..BUT it was the other cable that I replaced.
Is there a 'zeroing' process for this one too?...
Old 19-07-2019   #6
nikrox has donated!
Re: 1.4 Gearbox Ask
Old 19-07-2019   #7
nikrox has donated!
Re: 1.4 Gearbox Ask
On the basis of one cable has already snapped so the other one could to,and being a 'prevention is better than cure' kinda man I replaced the second cable too.
Following the video I adjusted the new cable and am pleased to say .....
Its like driving a new car..smooth gearbox !!!
Thanks again to this forum. Without it and all the valuble contributions we all make I would have been lost and my friend considerably more outta pocket.
Thanks Detroitdiesel, Bernievarian thanked for this post
Old 19-07-2019   #8
Belgium
Re: 1.4 Gearbox Ask
Thanks for the update Nick and congrats for the job (well) done, specially the prevention part. Your friend must be lucky to have a mate like you !!
Cheers, Bernie
Likes Detroitdiesel liked this post
(T) multipla gearbox, stilo gearbox drflaver Multipla 1 07-06-2012 17:48
(T) ducato1.9td gearbox citroen 1.9d gearbox dethleff Ducato 1 16-11-2010 14:34
(G) Guys ive got new gearbox oil leaking out my damaged gearbox exit plug. usedtohaveavaldisere Panda (Classic) 6 13-03-2010 19:48
(T) T-jet gearbox Vs. 500A gearbox creep Grande Punto 1 10-03-2010 14:17
(T) Punto GT Gearbox and Uno Turbo MK2 Gearbox samsonite Punto (Mk1) 0 22-11-2009 14:15
