Having just endured the joy of removing/replacing the EGR and
exhaust gas heat exchanger after 110000 miles on my 1.3 MJT
after it started pulling 0401 fault codes I found that the problem
was confined to the inlet manifold exhaust gas injector holes blocked. The corrugated stainless tube from the heat exchanger to the inlet manifold is welded at the heat exchanger end but
I was wondering if there is enough flexibility in the corrugated
tube to get injector tube out of the inlet manifold without removing the EGR? The tube seems quite stiff.
Is it possible to hear the EGR operating with an engine stethoscope?
How does the ECU detect low EGR gas flow? There are no obvious sensors in the EGR system.
The exhaust gas injector was covered in stick black gunk but
the interior of the inlet manifold seemed quite clean, I assume the source of the muck was the crank case ventilation.
