Hi Bernievarian, yes I assumed that your message on bolt sizes was for general benefit. And it is interesting anyway!
Not heard of ePer before but googled for it. Very useful if it works, but I am currently getting frequent error messages before I get to the page I would need. I will try again later.
My car is a 2008 model. 8v, 1.4 It definitely uses 8mm bolts for the main ones down either side of the sump, but as far as I can tell there is clearance around the holes so I assume these to be 10mm diameter, or thereabouts. I wonder if they changed the spec at some stage, to give more tolerance when fitting the sump. The 4 smaller holes at either end would hold the position accurately.
