R red robins New member Joined May 22, 2017 Messages 13 Points 6 Jul 15, 2018 #1 i have located the interior fusebox but it is behind a metal panel behind the usb bracket, how do i remove the panel to access the fusebox
Bernievarian Prominent member Joined Jan 15, 2017 Messages 2,993 Points 654 Jul 16, 2018 #2 Might be usefull to have a few information … version, date, drive etc. !!
Scottie1911 New member Parked in the garage Joined Nov 26, 2012 Messages 46 Points 13 Location Airdrie Jul 16, 2018 #3 You should be able to pull it off ,2 clips at the bottom and I think only 1 at the top
OP OP R red robins New member Joined May 22, 2017 Messages 13 Points 6 Jul 19, 2018 #4 2010 grande punto 1.4 petrol
Bernievarian Prominent member Joined Jan 15, 2017 Messages 2,993 Points 654 Jul 20, 2018 #5 I assume your drive Wheel is on the right side and therefore the fusebox is hidden behind/below the glovebox ?? BRs, Bernie
