MyForumName
- May 20, 2018
- 4
- 2
Hello everybody,
I'm trying to upholster the GP headlining / ceiling with new fabric. I've removed the headliner from the car. After removing the old (dirty/stained) fabric and scraping/sanding away remnants, I started applying a new fabric: some decently thick polyester curtain fabric I found at a bargain price. Unfortunately I messed up for not buying true headlining fabric: when I applied the fabric it did not possess enough stretch to cover the sun visor and other curved areas. Also the fabric didn't do a great job hiding all irregularities / glue brush strokes.
So I removed the new fabric, but the contact adhesive I used already did its job (Bison Tix) and it pulled the fiber glass off of some areas leaving the foam of the board exposed (see pics). Luckily I didn't glue the complete board yet.
My question is if I can just sand the board smooth at this point and try again with foam backed headliner fabric or do I need to add a new fiber glass layer to cover up the exposed foam (for adhesion)?
Any advice is much appreciated, thanks.
