Old 10-02-2016   #1
Boost pressure?
My turbo is not kicking in, I took the pipe off from the vacuum pump to the boost control sensor and there is quite a good suction but from the boost control sensor to the electronic turbo actuator there doesn't seem to be as much, The pipe appears to be clear and the pipe doesn't seem to be leaking. Can anyone tell me if the vacuum pump should be giving me loads of suction or just a bit. Thanks Mark
markymark123 is offline Reply With Quote Quote
Old 11-02-2016   #2
Re: Boost pressure?
Anyone
Old 11-02-2016   #3
Re: Boost pressure?
Not an expert but is it boosting when it's not supposed to. If so it maybe the boost control solenoid. Generally 2 maybe 3 if it's a variable geomatry item. Hopefully someone with better knowledge than I will be able to help you out.
Nathan6597 is offline Reply With Quote Quote
Old 12-02-2016   #4
Re: Boost pressure?
No its not doing anything
(T) JTD Boost Pressure widemouthfrog Multipla 3 07-03-2015 07:51
(G) Boost pressure 1.9 Sm1thygp Grande Punto 5 21-11-2013 22:49
(T) Boost pressure Mazhasai Stilo 3 24-05-2011 11:48
(T) boost pressure loss blinkyspoogle Coupe 4 13-01-2007 19:30
(T) Boost pressure syrill-sneer Uno 4 25-08-2005 16:56
