General Number plate lights for a 56 plate Grande punto
D8N13L
Does anyone know which led bulbs to use for a 56 plate fiat Grande punto active sport 1.4 for the number plate lights? Want them really bright, from what I've seen they look amazing, also if anyone could tell me what light to use for the interior light I'd 've grateful too
You can use any 501 LED bulbs to go into the number plate lights. Bare in mind you also need a pair not just one ! Even though, as good as they look, they will bring an error up on your dashboard even though they are working.
As for the interior bulbs (im guessing you mean the lights which open when you open/close your doors) you can fit LED bulbs to them no problem ! These are LED SMD Dome Festoon Bulbs. Its also worth taking one of them out and mesuaring how long it is so you can get the correct size for your model. 36mm-39mm rings a bell but like i said, double check :)
Does anyone know the code name for the headlight bulb on a Grande punto sport 2006?
I dont know if its h7 499, h7 501, h1, no idea
