- Apr 29, 2012
- 119
- 31
Hey people, as some of you know I own a Punto Abarth with a few mods:
De-cat
3" Full Straight through
GSR Induction
Forge Actuator
My problem lies somewhere with the turbo/wastegate/DV I think. If lets say im cruising at 70 on the dual carriage way and i put the boost to half it will surge and i can hear the dump valve opening and closing constantly which then causes the car to almost surge but if i put a bit more boost on or let off a bit it stops. It also happens in all the gears once i hit around the 3k RPM and the boost is roughly half way! Is this due to the Standard map? or something else? If anyone has any info please share
De-cat
GSR Induction
Forge Actuator
