If my 1.4 Sporting has been parked for an hour or more usually when I start it I'll get an error to check the power steering. If I turn the wheel full lock both ways and re-start it clears and is fine until it's been turned off and left for a while again.
30% of the time it will start without error.
It's been in the garage and the diag shows an error with the steering angle sensor so they changed the switch with no luck. Just to be sure they tried a 2nd unit, still no joy. They also mentioned the yaw sensor.
Looking for suggestions on what to try next.
Cheers!
Cheers!
