![]() | #1 | ||
Posts: 179 Thanks: 5 Trader Rating: 0 ![]() | No oil on dip stick? Hi everyone, I need some help.... I have recently done a oil and filter change last weekend however I don't get a reading on the stick? I've triple checked everything no leaks, right oil, and not problems with the Car at all just alarm bells are ringing with nothing showing?? I have had all 16 valves changed and some head work done around 6 months ago..... Any ideas please ![]() ![]() ![]() ![]()
![]() | #2 |
Posts: 284 Thanks: 10 Trader Rating: 0 ![]() | Re: No oil on dip stick? Did you put the right amount of oil in? |
![]() | #3 |
Posts: 83,516 Thanks: 1480 Trader Rating: 10 ![]() | Re: No oil on dip stick? new clean oil can some times look invisible, buy a packet of blue rizla and run the edge of one down the stick starting about 2cm above max
__________________ “The further a society drifts from the truth, the more it will hate those that speak it.” |
![]() | #4 | ||
Posts: 179 Thanks: 5 Trader Rating: 0 ![]() | Re: No oil on dip stick?
![]() | #5 | ||
![]() | #6 |
Posts: 7,567 Thanks: 586 Trader Rating: 1 ![]() | Re: No oil on dip stick? If the above test shows no oil on stick, we need to determine where it is. 1. Is the stick pushed fully in. 2. Check that the dipstick tube is properly seated and has not lifted. 3. Drain the oil into a clean container (so that it can be reused) and see if the right amount comes out. (Proof it was in there) 4. Is all the oil in the head instead of the sump? Have the drain channels become blocked during the head work, or blocked by wrong or incorrectly fitted head gasket. It can't disappear. There will be a logical solution.
__________________ 13 years motor trade, 16 years motor industry. 16 years Driving Instructor & 9 years Fleet Trainer Panda Alessi (2015 Skoda Fabia) |
![]() | #7 | ||
Posts: 179 Thanks: 5 Trader Rating: 0 ![]() | Re: No oil on dip stick? If the above test shows no oil on stick, we need to determine where it is. 1. Is the stick pushed fully in. 2. Check that the dipstick tube is properly seated and has not lifted. 3. Drain the oil into a clean container (so that it can be reused) and see if the right amount comes out. (Proof it was in there) 4. Is all the oil in the head instead of the sump? Have the drain channels become blocked during the head work, or blocked by wrong or incorrectly fitted head gasket. It can't disappear. There will be a logical solution. ![]() ![]()
![]() | #8 | ||
Posts: 179 Thanks: 5 Trader Rating: 0 ![]() | Re: No oil on dip stick? Quick update, it was blocked channels but all clean and ready to go ![]()
![]() | #9 |
Posts: 7,567 Thanks: 586 Trader Rating: 1 ![]() | Re: No oil on dip stick? How long ago was the head work? Who did it? How long has the engine been run in this condition? Since the head work, if the engine has been run, all oil pumped to the head will have remained there, reducing the available oil for the crank. If it has been run for some time, there could be significant crank damage. However, it is good practice to change oil after any such work, is this what has happened? If so, and engine has not run, then no worries. If the head work was done by a professional, is he responsible for the remedial work and consequential costs. Hopefully all is well now.
![]() | John2 | Marea | 2 | 04-11-2011 22:01 |
![]() | mzhussein | Stilo | 15 | 19-08-2010 19:46 |
![]() | donnabravo2k8 | Bravo / Brava | 2 | 26-11-2008 00:29 |
![]() | nerogk | Grande Punto | 24 | 24-04-2007 09:30 |
![]() | Shminkypinky | Stilo | 2 | 19-01-2004 04:38 |
