There is a bank of fuses in a black box under the bonnet on the right hand side if you read your manual it will say whitch fuse it is and what amage it is.
I warn you the fuse box lid is a beatch to replace properly, it must be replayced properly other wise water gets in then you really are fooked.
rigt ive found it its a 15 amp fuse top left corner of the little fuses under the bonet ive justfitted the fog lights following the guid and i kept blowig a fuse then relized id put a pos and a neg to a pos wire :bang: all sorted now
