That'll never be used.... just the other day i was speaking about this where i work (work as a mechanic) and the only reason i can think as to why is what IF a intake solenoid fails and sticks open ?????? its gonna bend a valve..... and the way new electrics are going it could fail at anytime.... not saying they wont bring it out, but i think personally it will be a while before they do.
If the solenoid gets stuck, the valve will open and close as it normally does based on the rotation of the camshaft. End of story.its got an ecu what happens when that breaks, your valve get stuck open an get bent?
That'll never be used.... .... not saying they wont bring it out, but i think personally it will be a while before they do.
why didn't they just invent an engine with no valves an have in take an exhaust working off some other sort of solenoid, so it would make all engines safe
do you mean like a rotary engine?
When your engine it spinning at 7,000 rpm, getting all these electric "gates" to open and close at exactly the right time must be tricky. And when the control circuits break, your engine could end up badly damaged.no a better one, still with pistons but with eletric gates instead of valves
how about valves that open up wards instead of down then
no some thing betterYou mean like a "side-valve" engine?
http://en.wikipedia.org/wiki/Flathead_engine
Like the article says- it's a simple design, but doesn't breathe well (which makes it no good in the modern emissions-driven world).
