Old 06-01-2009   #1
Se7enHP has donated!
T-Jet Suspension in comparison to Abarth suspension?
Exactly what is the difference between the two suspensions other than the dampners and springs?
For example.... Would buying Abarth Dampners and Springs render my T-Jet Suspension similar to the Abarth set-up?
Would either piece make much difference to the T-Jet set-up?
After owning a long string of French sports cars, 172, 205 GTI Mi16, 182 Trophy, 197 cup 172 cup, 182FF.... The Italian stallion 1.4 T-Jet... after years off the road I find myself back in an Exotica red M-Jet....... And I love it :-)
Se7enHP is offline Reply With Quote Quote
Old 06-01-2009   #2
Dub Dub Dub
Aircooledbug has donated!
Re: T-Jet Suspension in comparison to Abarth suspension?
Abarths is stronger and sturdier. More of a sporty feel. and its 15/20mm shorter
2006 Caribbean Orange 1.9 Multijet 130
Aircooledbug is offline Reply With Quote Quote
Old 06-01-2009   #3
Supercharger whine :)
Si - Punto's Avatar
Si - Punto has donated!
Theres not a huge amount of difference between the two setups iirc.
A quick snippit from an old AI magazine (Sep 08) lists the chassis differences from T-Jet to Abarth (standard version, not Esseesse) as "a bundle of chassis modifications including 10mm lower and stiffer springs, 6mm wider track, reprofiled dampers and 2mm thicker anti-roll bar (19mm thick as aposed to 17mm thick on the T-Jet)".
The article leads the reader to believe that these are only some of the changes, I couldnt tell you for sure if there are more (cant be bothered to compare part numbers on ePer).
Doesn't sound like too much of a stretch to meet, either speak with Chris@Souls about ordering the Abarth springs, dampers and anti-roll bar or try sourcing some of the following parts as an aftermarket alternative:
- Eibach springs
- Koni dampers
- 3mm wheel spacers
- Uprated anti-roll bar from the likes of Eibach or OMP (if available)
Should be dooable for somewhere between 500-1000.
I take it you've decided to stick with the GP and mod it rather than take the depreciation hit on such a new car
Good luck mate, hope you turn it into the car that it's capable of being
Aero kitted R53 Cooper S - Electric Blue/White Roof
Gone but never forgotten
'54 Steel Grey Punto Active 1.2 - '99 Nero Black Bravo HGT 20v - '98 Broom Yellow Punto GT3 1.4T - '07 Crossover Black Grande Punto Sporting 1.9 M-Jet
Si - Punto is offline Reply With Quote Quote
Old 06-01-2009   #4
Quote Originally Posted by Si - Punto View Post
- Eibach springs
- Koni dampers
- 3mm wheel spacers
Bang on mate, Christmas passed, I eyed Up a new 197 or a 2nd hand Mk5 Golf GTI, then realised WTF am I doing, I would for one be loosing in excess of 2-3k within a matter of 4 months, and for that sort of money at my disposal I could make my T-Jet into a 197 beater
So as they said back in Gladitorial days.... Let the games begin...... and the better half rip my bolloks off
Old 06-01-2009   #5
Si - Punto's Avatar
Fair play mate, wise decision and one which I would follow myself if I was in your situation.
The T-Jet isn't massively exciting as standard however it does have a fair amount of potention to be a cracking car, after all it's only a handful of readily available parts away from an Abarth.... and beyond
Keep us posted on your progression, should make for an cracking read
Old 06-01-2009   #6
Top Dog
Tris Harris's Avatar
Trader Rating: 1
Tris Harris has donated!
don't quote me on this, but doesnt the abarth use a different set up... ie, the standard GP has a torsion bar, whereas the abarth is more or less fully independant...
*runs off to find info*
Tris Harris is offline Reply With Quote Quote
Old 06-01-2009   #7
F/A-18 Hornet Champion
semi independent axle i think where as the t-jet is more of a solid state axle on the rear.
Se7enhp - YAY! you still coming to GSR end of the month? lil road trip?
clawliger is offline Reply With Quote Quote
Old 06-01-2009   #8
Top Dog
Trader Rating: 1
Quote Originally Posted by clawliger View Post
thats what i meant
Old 07-01-2009   #9
Banned
punto_matt's Avatar
punto_matt has donated!
Western Samoa
The rear beam is completely different to the standard Tjet one afaik. Then a slight wider track and different springs and dampers as people have said. I think a properly set up set of coilovers would easily match or beat the abarths handling.
punto_matt is offline Reply With Quote Quote
Old 07-01-2009   #10
coilies FTMFW!!!
yer different set up as i said.
Old 08-01-2009   #11
Greece
Quote Originally Posted by Se7enHP View Post
well concerning the anti-roll bar the magazines are completely out of knowledge.they claim 19mm bar while the ''normal'' versions are 17mm.if you check the part number from fiat you will find that they have the same diameter and more accurate if you measure an abarth one with a normal you will find exactly the same number.17mm.i know because before i decided to do my suspension modifications i was thinking the abarth one.no difference what so ever.
GDRIVER is offline Reply With Quote Quote
Old 08-01-2009   #12
Greece
Quote Originally Posted by GDRIVER View Post
sorry except the diameter they have the same part number
Old 08-01-2009   #13
Greece
Quote Originally Posted by punto_matt View Post
Old 08-01-2009   #14
Greece
Quote Originally Posted by Tris Harris View Post
some say torsion beam in the rear with 5% more strength.i have checked it my self to see that it is a torsion beam,semi-independant.
all torsion beams setups are concidered as semi-independant and can be combine with other setups,like limp arms or longitudinal arms.
(T) Abarth Suspension Old Boy Grande Punto 3 18-10-2008 16:39
Mountain Bike query - full suspension or no suspension? Chas Uno Leisure Lounge 18 13-06-2007 01:24
(G) Suspension parts,where to buy,how to check? Rear suspension guide? kritip Cinquecento / Seicento 6 31-07-2006 15:59
(G) Different suspension on an Abarth Squadrone Rosso Stilo 2 29-12-2004 23:56
(T) Abarth Suspension boywonder Stilo 3 19-08-2003 01:15
