Has anyone had any problems with first gear on any 06' puntos?? It goes in but I have to do it very slowly and it feels like its crunching. It's only done 13000 miles : S
I think it could be your EGR valve, I got this problem, but it doesnt grind. You need to check the pipe that goes to your EGR valve to see if it has a hole in it, if not then I got another thing for you to try...
no EGR on an active
the box is linked to the gear lever by cables it sounds like these need the tension adjusting by the dealer
ohh rite, whats the difference between active and active sport. Is it just bodywork or engine or both?!
1. Alloy Wheelsohh rite, whats the difference between active and active sport. Is it just bodywork or engine or both?!
