- May 25, 2006
- 16,219
- 2,029
I am perfectly aware you said it i was just explaining it to him better.
THE POLICE GUIDELINES said:The Police Service now uses technology that enables it to prove that an offence has been committed as soon as a driver exceeds the relevant speed limit by a very small margin. Motorists will therefore be at risk of prosecution immediately they exceed any legal speed limit.
The guidance to police officers is that it is anticipated that, other than in the most exceptional circumstances, the issue of fixed penalty notices and summonses is likely to be the minimum appropriate enforcement action as soon as the following speeds have been reached:
Limit Fixed Penalty Summons
20 mph 25 mph 35 mph
30 mph 35 mph 50 mph
40 mph 46 mph 66 mph
50 mph 57 mph 76 mph
60 mph 68 mph 86 mph
70 mph 79 mph 96 mph
Fixed penalty of
1. £60 (pending)
2. Licence endorsed with 3 penalty points Magisterial discretion (level 2) maximum of:
1. £1000 fine
2. Licence endorsed - range of penalty points available
3. Disqualification
4. Compulsory re-testing
This guidance does not and cannot replace the police officer's discretion and they may decide to issue a summons or a fixed penalty notice in respect of offences committed at speeds lower than those set out in the table. Moreover, in particular circumstances, driving at speeds lower than the legal limit may result in prosecution for other offences, for example dangerous driving or driving without due care and attention when the speed is inappropriate and inherently unsafe.
Oi Stripes!Originally posted by: Stripes
I can believe it, was still pulling like a b*tch at 115....but I wonder what damage it is doing to the engine/turbo doing 141! Surely the oil won't get around it quick enough. Must be sitting at about 4000 revs?Originally posted by RossHutchie
The M-jets will fill the clock and more after a remap. Your right about the clocks over reading, the most ive seen mines at on the Sat Nav is 141mph with still a little revs left![]()
No if you go through a camera the general rule is you get 10% on top of what ever the speed limit is where the camera is ie in a 30mph zone your normally fine up to 33, 50mph zone is 55mph etc etc.
And do you have alot of keys missing from your keyboard or something?
as for the 2nd bit what difference does it make if i type like that? u quite clearly could read it so...
I was always lead to believe the speedo overreads by a certain amount as an 'error buffer'. So that if the speedo does become inaccurate/faulty etc chances are it will still display a speed greater then what you are actually doing.
All the cars i have driven (which is quite a few with work) and used sat nav/gps in have always overread the speed on the speedo.
lol my standard Tjet only just managed to touch that on my private road so god knows how NA 1.4 got there.
one time me and some friends managed to get some time in at an airstrip, and i managed to hit 130 mph on a 1.4 16v and still had quite a few revs to go, but i got scared cuz it felt like the car was going to desintegrate and didnt gas it anymore after 130. I probably wont ever go that high anymore.
It must of took some doing getting back up such a steep hill as that "Airstrip" was built on![]()
