Does anyone have a glovebox that they find hard to close (have to use alot of pressure).
Just found out this is a common problems with the GP gloveboxs!
I kind of think it could an alignment issue - mine when closed still flops a bit on the right hand side. do others do this?? but like I said I haven't found anywhere to adjust this!
Had the same problems with mine then soon after the latch gave way and I could close it at all.
Had it fixed under warranty only to have the same problem a few weeks later. So I ended up fixing it myself. Just a simply case of unscrewing the 3 screws, push the latch back in place and screw everything back.
Hardly worth a trip down to the dealer.
Mine is in 3 pieces at the moment, and they can have it back like that too. I hope the S2 cars have had this issue rectified. It's a shockingly bad piece of engineering
Mine was has never been put right no matter what the dealer has done!
Mine quite often just falls open when im driving along. It is also quite hard to close sometimes.
Might be worth a trip, takes about 2 minutes. Might save you the hassle of it falling open and being hard to close. If it bothers you that is
