georgios1976
Member
It sounds like it could be the EGR valve. I had the same problem on the wifes 1.9 Sporting. No power low down then picked up at about 2500rpm. No warning lights and no fault showing on diagnostic but turned out it was a sticking EGR valve. They did try cleaning it out as an interim measure but problem came back the next day and the valve was replaced under warranty.
I've got EXACTLY the same problem, first noticed on Monday (3 days ago)!!
My Sporting JTD is flat up to 1800 revs, between 1800-2400 revs it pulls like a small engined normally aspirated petrol, then turbo kicks in at 2500 revs and she's flying!
Booked her in for a check at Ashmoles in Swansea, will defo suggest the EGR valve. Thanks to you guys I can sleep easy at night! I initially thought it was down to rubbish Tesco diesel or even worse, that the engine was giving up the ghost!
Respect to you all!:worship:
