FIAT Auto Specialist Team
Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->Central Door Lock Actuators Repair<!-- google_ad_section_end -->
Published by mankam
09-11-2017
Difficulty Level: 3
User Rated:Unrated
If some door is not lock from the remote key this is a Guide to make first a Diagnosis and repair it.
All the locks have the same mechanism, they differ only if it is left right or the back door.
I will not describe how the doors lock Removal because there Guides who describe it :
https://www.fiatforum.com/grande-pun...nt-repair.html
You will need
a set of Torx drivers
Screwdriver & allen set (to remove the door panel.)
a dremel with a cutting wheel.
After remove the door lock mechanism you you can see the 6 pin connector.
The photo below is the 2 contacts which control the remote locking motor.
You can connect carefully 12 volts to τo hear the sound and vibration. polarity is not important if you redo lock it unlocks.
If the motor is running the problem located somewhere else, Usually in the door wiring loom, i have seen many cut wire between the door and the body inside the rubber.
If the motor no working you must cut with a Dremel as you see with red line in photo and remove the torx screw.
Carefully remove the motor, do not damage the plastic gear, use a small screwdriver.
As you will see, there are two contacts in the plastic (red arrows in photo) that give a 12v to the motor, You need to clean it, i use a contact cleaner but a alcohol is enough.
Name:	DSC_04972 - Αντιγραφή.JPG
Also you need to clean the contacts back on the motor, a trick is to use a needle to make the pins springs harder.
Name:	DSC_09470 - Αντιγραφή.JPG
Put the motor carefully back, now before you close it check if the motor working good using the door connector as you seen in this video.
Hope this helps
Thanks Lofty123, judderbar thanked for this post
Likes judderbar liked this post
Old 28-11-2017   #1
Re: Central Door Lock Actuators Repair
Thanks for the guide!
The issue I have is the central locking on the drivers door only works when locking the door. I can hear the the motor clicking locking & unlocking?! Is the issue more likely the wire loom??
cheers
Pastars is offline Reply With Quote Quote
Old 29-11-2017   #2
Greece
Υes is possible to hear the motor if it works, also take a look inside the door rubber a have seen many cut wire inside, in my case the mirrors right and left not working and the passenger window.
mankam is offline Reply With Quote Quote
Old 12-03-2018   #3
PRJ S4 has donated!
My recently acquired 2006 Punto GP 130 will not unlock manually with the key ( ie the old fashioned way !) I suspect that the key has never been used in the drivers door lock, and I do not want to snap the key ( its the only one I have !)
Is there a guide as to how to remove the door card and access the mechanical parts ?
PRJ S4 is offline Reply With Quote Quote
Old 19-09-2018   #4
Thank you
slew is offline Reply With Quote Quote
Comment
Search this Guide:
central door lock wiring diagram Mladen Ifkovic FIAT Boo Archives 11 18-02-2005 10:13
