Comment
Guide Tools Search this Guide
Breather hose replacement 1.2 & 1.4 8v
Andy Monty
08-02-2011
Oil / Fume smell drawn in by your heater / blower which goes away if you stick it on recirculate it could be your breather hose has split...<br />
<br />
tools needed<br />
<br />
10mm spanner / socket, ratchet and short extension<br />
<br />
end cutters or CLIC AND CLIC-R type pliers<br
Old 10-03-2014   #30
kyle96 has donated!
Re: Breather hose replacement 1.2 & 1.4 8v
Quote Originally Posted by Andy Monty View Post
yes it can be bloody stuborn to come off the bottom though
Hi andy
Do you know the answer to this question?:
Quote Originally Posted by Andrii View Post
Hello,
I change my stock air filter with a K&N 57i Series Induction Kits (57-0655), and the installation guide tells me that I must block the air breather hose (not oil breather hose, it is a very narrow rubber hose, under air filter). It is ok or wrong to do that? What is the meaning of air breather hose?
It's been annoying me for a while now
^First car
Currently own an orange 1.9 mjet sporting
kyle96 is offline Reply With Quote Quote
Old 10-03-2014   #31
Moderator
Andy Monty's Avatar
Andy Monty has donated!
What answer?
Old 11-03-2014   #32
kyle96 has donated!
Sorry if I was unclear, it was in the quote by @Andrii in my reply.
I have a 57i k&n induction kit (Don't use it though,) And when installing it it tells you to block off a small breather hose with a plug that's provided, and I've always wondered what purpose does that pipe serve, and why can it just be 'blocked off' as told to do so in the instructions?
^First car
Old 13-11-2014   #33
asked every time I put it in for service "cant find any problem", pipe was nearly falling apart when I looked at it
Likes Andy Monty liked this post
christurnerchris is offline Reply With Quote Quote
Old 07-12-2014   #34
Barry1955 has donated!
Had exact same problem. Car in for MOT, asked them to find source of petrol fumes in car, was told they found nothing wrong. I decided to service TOH`s car myself and found BOTH breather hoses split in two when I changed the plugs and air filter,( could see split hoses before taking any thing off ) Most garages are a joke. ps; Fiat wanted 11.00 plus vat for the small hose; got some fuel line hose from factors for 2.79
Barry1955 is offline Reply With Quote Quote
Old 24-02-2015   #35
Hi guys, recently replaced the main breather pipe, and noticed the small, longer one could do with replacing....obviously, from replacing the large pipe, I know where/how the small pipe fixes to the airbox....but....does the pipe just pull off at the other end? Is it easy to access?
SCL is offline Reply With Quote Quote
Old 09-09-2015   #36
Hungary
Hello,
there is an aftermarket hose on the market with very good quality and with the same size/shape like Fiat original one: IMPERIUM 19182
Grande Punto 1.4 8V 77HP
szasz is offline Reply With Quote Quote
Old 11-10-2015   #37
What answer?
Hi I just tried to trouble shoot the source of the exhaust smell and noticed that the plastic bit that the small breather pipe connects to at the top had snapped off and stuck in the small breather pipe. Where can I find the replacement part? Does anyone know what the part number or name is? Can I fund something at the local independent?
Any advice would be much appreciated.
sal12349956 is offline Reply With Quote Quote
Old 31-03-2016   #38
Used this guide to replace my breather hose and the thing had a fat six inch crack on one side and two three inch cracks on the other.
Car was serviced by a mechanic less than 3-4 months ago, the spark plugs were supposedly cleaned so they must have taken off the air box, how could they have missed this?
nickbob00 is offline Reply With Quote Quote
Old 14-06-2017   #39
hi guys anyone know what size hose i need,inner bore for the one that connects to he rear of the airbox?
many thanks
GPmo is offline Reply With Quote Quote
Old 18-08-2018   #40
Vatican City
Cool Re: Breather hose replacement 1.2 & 1.4 8v
Replacing hoses is not enough. Three pages and no one mentioned term "PCV".
You should check/inspect entire PCV (Positive Crankcase Ventilation) system.
It's so called "fixed orifices PCV" system (there's no valves, one-directional).
One orifice (bigger, for thick/main hose) is inside air filter box.
Second (smaller, about 1-2 mm diameter) is in the intake manifold nipple (where you connect small hose). Check/clean both periodically. When small hose breaks down, debris can clog orifice "2" (picture explains it all).
Small hose can be substituted by suitable fuel line rubber hose. Don't be that lazy, go figure out the diameters by yourself (you have old one to compare/measure).
Likes stroy liked this post
GrandePunto PL is offline Reply With Quote Quote
Old 05-01-2019   #41
Vatican City
Post Re: Breather hose replacement 1.2 & 1.4 8v
Of course, modern materials are better. Old hoses were plastic + rubber blend (PVC+NBR).
Other classic rubbers will not survive very long too (like EPDM).
New, improved breather hoses should be made from FKM+EAM (it's probably "Viton" + something), it feels more like silicone.
Old 26-11-2020   #42
Quote Originally Posted by GrandePunto PL View Post
Attachment 193252
Came across this video. Not in English but has subtitles.
https://youtu.be/baCtGCiCU90
Likes Balak liked this post
Liam1804 is offline Reply With Quote Quote
Old 4 Weeks Ago   #43
Israel
The design and location for the breather is wrong, it makes a mess in the throttle body:
So I have change it, drill a hole in the filter box and made the hose go up straight from the engine, the height difference only lets the fumes go in, not the oil, since then my throttle body is clean :-)[Yes, I have sealed the other end where it supposed to go]
Grande2007 is offline Reply With Quote Quote
Comment
Search this Guide:
(G) Breather Pipe/ Hose dansmitts Grande Punto 5 09-02-2011 10:10
(G) Breather hose replacement Luca91 Punto (Mk2/2b) 4 06-02-2011 20:15
(T) Breather Hose RobSport Grande Punto 6 12-10-2009 21:24
(G) K&N 57i breather hose Aliweasel Cinquecento / Seicento 15 18-11-2007 00:58
(T) 899CC Breather Hose badboyz016 Cinquecento / Seicento 11 28-07-2004 19:44
