Grande Punto My Grande Punto T-Jet 120
Got this car in January this year with 145,500 km's on the clock from an acquaintance. It was a bit of an impulse buy as I was looking to get an Abarth 500, but this popped randomly while scrolling around, and I fell instantly in love.
I'm planning to do some small mods to this car, as I'm very keen on keeping it in top shape and I want to drive it for many years to come.
The previous owner repainted much of the body panels, installed a new VL36 turbocharger, exhaust manifold, deleted PCV, bigger FMIC, Abarth camshafts and H&R lowering springs. I've installed an oil catch can, tyres, changed the handbrake cables, and one rear brake caliper needed to be changed.
I plan to have an cat back stainless steel exhaust (straight piped, but i'm a bit afraid it would be a bit noisy and obnoxious lol), and a remap. I'm looking for 160-180 bhp from this setup, nothing crazy, just enough for a bit of fun. I don't know how much power it currently makes, it wasn't dyno'ed.
Also, I plan to have the diamond cut finish redone on the rims as they are a bit scuffy and scratched. And maybe in the future I'll get some big Brembo calipers from an Abarth 595, coupled with some Bilstein B6 Performance shocks.
  • Like
Reactions: Didge3
Latest updates
So, all planets have aligned, and the Punto is pretty much done. I had a lot of work done on it, I'll have a short list here:
-> I've changed the problematic right side drive shaft, unfortunately, this was a lot more work than anticipated. The new driveshaft was made for a Fiat Doblo mk2, and was too long (930 mm vs 921 mm). I had the outer shaft shortened, machined and TIG welded. The vibrations are a lot less upsetting right now. We'll see how long it's going to last.
-> New clutch, release bearing and flywheel.
-> New timing belt and water pump.
-> New steering arms with new rods and links.
-> New alternator belt.
-> New coolant expansion tank.
-> New drilled Brembo XTRA line disks on the front, and Brembo OEM in the rear.
-> Added a K&N drop in filter
-> Mounted new Eibach 12 mm wheel spacers with longer bolts front and rear.
-> Added a metallic engine splash shield (car is quite low and I don't want to damage the oilpan).
-> Oil and filters. Motul Abarth spec 10W50 + Liqui Moly Ceratec, and Motul 80W90 with Liqui Moly Gear additive.
-> Lots of details, used some rust converter on any suspension, thing that was showing even a tiny bit of rust, oiled the shifter linkages as they stick a bit (they'll need replacing).
-> Alignment
I managed to buy a new set of identical rims, but in a lot better shape, without any curb rashes.
I'm very happy on how this car turned out. I love it, and every time I go for a ride, it puts a smile on my face. It's an undercover Abarth Grande Punto SS. With this new K&N filter, and especially the new flywheel (it's OEM Luk, but apparently it's a bit lighter even though it's dual mass), the throttle it's a lot more snappy and crisp.
It's not perfect (there are places where the car shows it's age) but for me it's good enough. I've yet to see a Punto in a better shape than this one :D.
Can't wait to do some trackdays.
  • Like
Reactions: Dario
Winter is here, and due to holidays, I managed to get some work done on the GP.
-> H&R CupKit Komfort dampers + springs
-> EBC Yellowstuff brakepads
-> New rear suspension bushings
-> New damper bushings
-> Front calipers rebuilt and painted
So far so good. There are a few things needing taking care of (an alignment is next) but these really transformed the car.
Managed to have a custom 60 mm stainless steel cat-back exhaust system done, and a remap. Painted the rear bumper, side skirts, and polished a bit all the scuffs on the rims. Changed the filters and put some Abarth spec'd Motul 10W50.
I've kept the "stock" exhaust configuration, with a mid muffler and a baffled rear one, as I don't want it to be too loud. I'm looking for the stock Abarth Grande Punto experience :D.
The stock configuration was producing 150 hp and 243 N/m of torque. The remap changed the whole car, now it's producing 183 hp and 296 N/m of torque on 100 octane fuel. The acceleration curve is a lot more linear, the car is running a lot smoother, and the fuel consumption went down quite a bit. It's quite fast and rowdy now without being too obnoxious. Now I'm running 102 octane fuel as a test, a bit expensive, I reckon it's adding 2-3 hp max, but the throttle response seems a bit more tight.
Now I just need some Bilstein B6 shocks, new front brake calipers, EBC Yellowstuff pads and rear trailing arm bushings, and this hot hatch is pretty much done.
Table of contents
Vehicle information
Registration
BV25***
VIN / ePER
ZFA1990**********
FIAT Cars
SnuffRadu
Views
661
Watchers
1
Updates
3
Last update
Vehicle specification
Colour
White
Trim
T-Jet Sport
Year
2009
Fuel Type
Petrol
Engine Size
1368cc
Gearbox
Manual
Doors
3
More in FIAT Cars
