![]() | #1 | ||
Posts: 20 Thanks: 0 Trader Rating: 0 ![]() | Knocking noise while turning Hello all I have a fiat marea 2001 elx auto and last month it developed a knocking noise when turn left or right and while stationary turn the wheel left to right and it knocks. I've replaced droplinks already
![]() | #2 | ||
Posts: 26,556 Thanks: 1022 Trader Rating: 0 ![]() | Quite possibly ii its the bearing on top of front shock.. it gets sticky.. and holds top of spring tight As you steer.. the bottom of spring twists Itll only twist a little then pushes the top bearing round.. often with a BOING from the spring Common issue on later puntos ![]() Mareas.. I had 2 jtd weekends.. ![]() Charlie
![]() | #3 | ||
Posts: 20 Thanks: 0 Trader Rating: 0 ![]() | Hi. Quite possibly ii its the bearing on top of front shock.. it gets sticky.. and holds top of spring tight As you steer.. the bottom of spring twists Itll only twist a little then pushes the top bearing round.. often with a BOING from the spring Common issue on later puntos ![]() Mareas.. I had 2 jtd weekends.. ![]() Charlie
![]() | #4 | ||
Posts: 20 Thanks: 0 Trader Rating: 0 ![]() | Re: Knocking noise while turning Had the fiat for two years now it's the first time it's gone wrong it's such a beautiful car
![]() | #5 | ||
Posts: 26,556 Thanks: 1022 Trader Rating: 0 ![]() | Re: Knocking noise while turning Look in the Grande punto section.. Same basic strut design.. But less trim to remove on a marea ![]() Have a look at the forums GUIDES https://www.fiatforum.com/grande-punto-guides/259519-strut-top-bearing-removal-service-replacement-front-spring-replacement.html
![]() | #6 | ||
![]() | #7 | ||
Posts: 20 Thanks: 0 Trader Rating: 0 ![]() | Re: Knocking noise while turning Cool man hey Thank you so much for the information buddy I can't thank you enough. I also suspected the lower balljoint on the wish bone or the driveshaft as they can pull when turning if they naff. This car has had me scratching my head for weeks lmao
![]() | NickFontana14 | Grande Punto | 11 | 18-02-2018 13:00 |
![]() | MikeSporting | Punto (Mk2/2b) | 6 | 19-11-2013 16:22 |
![]() | SgtMunky | Punto (Mk2/2b) | 17 | 10-08-2012 08:06 |
![]() | deanm1 | Grande Punto | 4 | 16-02-2012 14:20 |
![]() | david295 | Punto (Mk2/2b) | 6 | 14-10-2010 22:24 |
