Right, a guy at my work has a mk2 punto and is complaining about the clutch slipping, however, he says it doesn't slip all the time, if it slips on the way to work, it won't slip in the way home or vice versa. He also mentioned that its stinking of oil (which I've yet to smell to determine gear or engine oil). My thoughts are that the clutch is f**ked and requires replacing, also would be worth replacing rear crank seal, and checking gearbox/replacing gearbox if required.
Or is it worth repairing?
