A Ant Wells Guest Jul 21, 2011 #1 are they easy to replace? Don't fancy paying the cost at a garage and I know it's basically a bit of copper pipe. Cheers, Ant.
A axle Guest Jul 21, 2011 #2 easy enough to do, You can buy the pipe and flaring tool off ebay or you can get the pipes made up at most motor shops. Dont forget when bleeding the rear wheels to have the weight of the car on the hubs
A axle Guest Jul 21, 2011 #3 http://www.ebay.co.uk/itm/Silverline-633545-Brake-Fuel-Pipe-Flaring-Tool-Kit-/170555846311?pt=UK_Hand_Tools_Equipment&hash=item27b5ebaea7 This post contains affiliate links which may earn a commission at no additional cost to you.
A axle Guest Jul 21, 2011 #4 http://www.ebay.co.uk/itm/3-16-X-25-FT-22G-COPPER-BRAKE-PIPE-C-W-20-METRIC-NUTS-/200534067585?pt=LH_DefaultDomain_3&hash=item2eb0c30981 so that is your outlay so you can se how much you are saving. if you dont fancy making your own pipes the garage will make em up for you, you will need the length of each pipe and the male or female unions for each pipe for comparison This post contains affiliate links which may earn a commission at no additional cost to you.
