Hi - is it easy to check and adjust front toe-in yourself, e.g with an adjustable length of pole or something to do measurements, or is it likely to be too inaccurate?
Same as Sven says, It is possible but far easier and more accurate using the equipment at the tyre shop. Most places don't charge if no adjustment is needed. About £12 to adjust unless a specialised 4 wheel alignment
