M
Martin
Guest
I had my clutch changed about 3 months ago, 1.4sx bravo. Ever since if i start the car and try to select reverse it grinds. But if i select 1st and then select reverse there's no issue, also if i start the car with the clutch depressed and the let the clutch up and select reverse it selects without an issue. is this just because this car is a fiat or is there logic behind this.
