Replacing cracked headlight on Brava
P
Paul
Guest
Drivers side headlight is cracked and needs replacing soon....what price do I expect to pay? Can I fix it myself if I get a spare from a scrap yard??
The headlamp is easy enough to replace as long as you are careful in disconnecting the cables. Look on the new headlamp for clues as to where the clips fit as some of them have to be done by feel. Undo the clip properly and they just slide off - you don't need to be brutal!
You may need to have the lamp realigned. When I did mine I didn't need it so you could be OK.
Headlamps are about £100 ish from autofactors, may be cheaper from a scrappy but you will be lucky to find one. Someone here on the forum may have one, sep if they have done the Marea conversion. Worth asking.
Nick
Cracked headlight lens only--Anyone got a spare?
Only the glass lens is cracked...do i have to replace the whole kaboodle?
Yes
Yes. You cannot buy the glass separately and even if you could you wouldn't be able to seal it.
Nick
Re: Yes
If it's a stone chip you can normally get away with just putting silicone sealent in the crack. If not then you have to replace whe whole light unit as they are sealed to prevent condensation. I got mine for about £68 ex vat each new from a place in sheffield called autospares, 01142752920. They are easy to replace, although difficult to get at. In the 1.6 if it's the right one there is a hose you have to take off and if it's the left the washer bottle limits your working space. There is a pivot ball joint for the load level where the light unit meets the grill which you have to be careful of but apart from that it's easy!
Re: Re: Yes
Get yourself some repair tape.
I got some a few years ago for my old Teapot 1.4 DGT. Used to come with a roll of clear and a roll of red. Used the clear on a chipped headlight, lasted for 3 years or more.
Mark.
Similar threads
S
Replies
3
Views
7K
Dark Lurker
D
D
Replies
Views
6K
David Slaney
D
J
Replies
Views
679
jason
J
G
Replies
2
Views
649
T
D
Replies
Views
540
Dark Lurker
D
