Bravo Idling Gone Berserk!
J
John
Guest
I've just been out in my 1999 1.6 SX. I pulled up at the lights and the tickover shot up to 4500rpm and wouldn't come back down.
I limped back home with the throttle racing every time I depressed the clutch, and had a look under the bonnet but can't see anything a matter. Throttle cable still connected and apparently working OK.
Anyone know what's a matter with it??
Also I'm looking for a head unit for it, got one?
Throttle Body
Mine did the same and I had a new throttle body fitted. Mine is fly by wire, I am not sure about yours though so problem could be elsewhere.
N
Re. Fly by Wire
If Fly-by-Wire means that you have a throttle cable connected to something with two small metal cans with multiplugs on the back, then I think it may well be.
Can you remember how much it cost?
Something like that.
I had it fixed under warranty and dont actually know the direct cost. About £400 was on the total bill if I remember.
N
It will probably be the idle control valve sticking. Got a haynes manual?
Haynes manual
Tom,
No I haven't, didn't think I'd need one on a 3 year old car, shows I've never had a Fiat before eh?
John
Re: Haynes manual
@ John
maybe this could be of some consolation....After 2 years my 1.6sx did the same thing do. Infact worse than yours...when I started the car the rev counter shot straight to 6000rpm. I switched it back off and when I restarted it shot up to 3000rpm fell back down to 1000rpm and then back up to 2000rpm then down, up, down and so forth. I managed to drive back home and when I restarted it worked as normal. Two days later the same thing happened but the mystery was resolved by itself. Another 3 years have gone buy and it hasnt done it ever since....funny these Fiats.....
Re: Re: Haynes manual
ive also got a 1.6 and mine did the same one day but its fine now. dont know what was up with it, it curred itself somehow.
its not much help to u though, sorry
Re: Re: Re: Haynes manual
Fiats are like plants...talk to them and they'll be alright. Sometimes I almost believe in it.
Similar threads
S
Replies
1
Views
481
T
M
Replies
Views
7K
M
A
Replies
1
Views
11K
Angelo
A
I
Replies
Views
621
IMC63
I
