| Thread Tools |
![]() | #1 | ||
Posts: 6 Thanks: 0 Trader Rating: 0 ![]() | ![]() hi everyone im a newbie , pleased to be here Fiat croma boot will not unlock using key fob anyone know what could be wrong , dont think it is the fob as doors work fine , thanks
![]() | #2 | ||
Posts: 20,605 Thanks: 731 Trader Rating: 0 ![]() | Re: Mackem Magpie Hello Northeasterner ![]() Im guessing this is a GM croma.. not an Alfa : Saab of the 80's Member @g8rpi is a good bet with the later GM (SAAB)2006'ish Dead microswitch in tailgate is a possibilty.. But Ive no Croma experience ![]() Charlie
![]() | #3 | ||
Posts: 4,113 Thanks: 418 Trader Rating: 0 ![]() | Re: Mackem Magpie I'm out of the UK at the moment with little computer access. I'll look on sunday, but if I recall correctly there is a menu option to disable the tailgate opening with the fob. Does it open OK on the handle? Robert G8RPI.
![]() | #4 | ||
Posts: 6 Thanks: 0 Trader Rating: 0 ![]() | Re: Mackem Magpie Thanks but it doesnt have a handle to open , everything from the fob , when i try to open the tailgate the lights flash but it doesnt click and release
![]() | #5 | ||
Posts: 6 Thanks: 0 Trader Rating: 0 ![]() | Re: Mackem Magpie ok thanks
![]() | #6 | ||
Posts: 6 Thanks: 0 Trader Rating: 0 ![]() | Re: Mackem Magpie Ok Thanks
![]() | #7 | ||
![]() | #8 | ||
Posts: 20,605 Thanks: 731 Trader Rating: 0 ![]() | Re: Mackem Magpie Looks like part #3 https://www.fiatdalys.lt/en/catalog/...s-and-switches Look at other section for mating parts ![]()
![]() | #9 | ||
Posts: 20,605 Thanks: 731 Trader Rating: 0 ![]() | My new panda felt like that.. I had to grt used to the operation of the pad switch.. Other option is attemp to remove tailgate inner trim and manually open the lock..to get the hatch in the air .. and then see what isnt working
![]() | #10 | ||
Posts: 6 Thanks: 0 Trader Rating: 0 ![]() | Re: Mackem Magpie Yes soft touch pad under rim
![]() | #11 | ||
Posts: 4,113 Thanks: 418 Trader Rating: 0 ![]() | Re: Mackem Magpie Does it open with the soft pad? (this only works with all doors unlocked so you may have to press the door unlock twice) You can select which doors open with the door button, either just drivers door, all doors or all doors and tailgate. This is done via the menu system "KEY" function. If you select "ALL" then the tailgate should open with the doors. This will rule out a problem with tailgate button on the fob. If it does not open with the doors when you have set key to all you have a actuator or wiring issue. If it opens with that but not the soft button you hve a microswitch issue (search the Croma forum for old posts on this) If it open with doors and soft pad but not the tailgate button on the remote you have a remote issue. One thing to note is that if you close the tailgate with the doors locked the tailgate will lock when you close it so don't EVER put the keys down in the boot (e.g. to lift something out) bcuse if you cloe the tailgate you will lock the keys inside the car. Robert G8RPI.
![]() | #12 | ||
Posts: 6 Thanks: 0 Trader Rating: 0 ![]() | Re: Mackem Magpie Thank you i believe it is an actuator problem . at least i now know what it is , it will be a couple of weeks untill i can sort it out , but im sure it will be resolved , thanks for your help and effort
![]() | #13 | ||
Posts: 20,605 Thanks: 731 Trader Rating: 0 ![]() | Re: Mackem Magpie SEARCH on here should find relevant info.. just in Croma section ![]()
Thread Tools | |
500 little magpie !! | elsie | Members Motors | 5 | 18-09-2009 00:27 |
![]() | elsie | 500 | 13 | 17-09-2009 22:07 |
Mackem Palace. | Hellcat | Leisure Lounge | 18 | 27-10-2007 14:28 |
