Thread Tools
Old 16-11-2018   #1
Mass air sensor
Not sure whether to continue with my LOSS OF POWER thread as this is linked but thought I would start a new thread.
Does anyone know whether a Vectra Mass Air Sensor will work on my 1.9 Diesel Croma.
Ended up taking to local garage to try and cure the loss of power and after changing the fuel filter (to no effect) the MAS was disconnected and the car seems to run better, not perfect but better. So, the garage says they will quote me for a Vauxhall MAS as it is the same. However I am a bit concerned that it may be the same as the steering pump in that it looks the same but incompatible because of software differences.
Anyone know?
Daveof49 is offline Reply With Quote Quote
Old 17-11-2018   #2
Moderator
g8rpi's Avatar
g8rpi has donated!
Re: Mass air sensor
I'm 99% sure it is the same. No software in the sensor and pretty standard Bosch unit. If it does not fit it's the garages problem.
g8rpi is offline Reply With Quote Quote
Old 30-11-2018   #3
Re: Mass air sensor
Yes the Vectra MAS does fit and work.
It has improved the performance but not taken it on a motorway yet.
However, it failed to start this morning cos of a flat battery.
As the MAS was only fitted last week is there a connection or have I just got a bad battery?
Old 30-11-2018   #4
Moderator
g8rpi's Avatar
g8rpi has donated!
Re: Mass air sensor
Quote Originally Posted by Daveof49 View Post
Did you disconnect the battery when fitting the MAP? If so you may have disturbed a connection. Check the battery clamps are tight and the fuses in the positive connetor box are OK. The MAP itself will not flatten a battery.
Robert G8RPI.
Thread Tools
(T) Multijet Air Mass Sensor Shuggie Panda 0 03-03-2014 11:35
(T) Mass Air Flow Sensor twincamms Bravo 0 14-12-2010 21:54
(T) Mass Air Sensor Pipe Mad Matt Barchetta 5 07-04-2008 10:31
(T) Where Can I Get A Mass Air Flow Sensor?? Texastel Stilo 14 22-12-2007 16:47
(T) need help with mass air flow sensor???? stilosporting Stilo 4 23-12-2006 09:13
