captainricard
Hello
I am a French owner of a 2006 1.9 JTD 150 Cromma with connnect nav + and this is my first post to find some help after read a few posts in this forum.
FM reception is not good with the connect nav+ i changed the antenna (not it's base and wire, just the antenna) without improvement.
As i found the connect nav+ a little outdated i am thinking to replace it with a standard 1 din or 2 din radio without GPS (i prefer bluetooth functionnality and GPS/MP3 through my smartphone).
I know that i must buy this type of accessories to fit the new device :
example for 2 din : http__/www.carteq-autoradio.fr/support-set-integration-cadre-double-din-fiat-croma.html
example for 1 din : http__www.carteq-autoradio.fr/support-autoradio-fiat-croma-rubbertouch.html
But do i need some iso adaptors ? keeping steering wheel buttons is not necessary for me.
I saw i topics related to install a connect nav that plugs on the car and behind the device a isos ones but i am not sure !
For a 2 din i should choos this one :
http__www.rueducommerce.fr/Equipement-Automobile-GPS/Sono-et-video-voiture/Autoradio/PIONEER/4882914-Autoradio-Pioneer-FH-X700BT-2-Din-CD-USB-et-Bluetooth.htm
And this one if it is a 1 din :
http__www.rueducommerce.fr/Equipement-Automobile-GPS/Sono-et-video-voiture/Autoradio/PHILIPS/4878899-Autoradio-Philips-CE152-USB-SD-Aux-Made-for-iPodiPhone-Bluetooth.htm
But before that i need to be sure that poor radio reception is related to the connect nav and not the wiring between the unit and the antenna (i hope not, i do not think that i am able to unmount the entire roof of the car to check this cable)
thank you for the answers
