Ever felt being a wally? Wondered what you did wrong?
So, I'll set the scene.
You of course have fully read and inwardly digested your Croma (other) owner's handbook, especially the section about the remote not working.
So it happened to me.
Zimples!
You try remote nearer the car, under the wheel arch, in the windscreen etc. Try all remote buttons incase one was duff.
Now you resort to the emergency key. Yes you remember that your remote fob contains a mechanical key that you can use. You lift the door handle, find the lock, insert and turn......nothing! You now try clockwise and anti-clockwise....nothing again. Bang / shake the fob and try remote again. Nothing. But the led on the drivers door is blinking so there must be some power in the car.
Call wife, bring spare key. Bingo and return home. When you get home the once duff remote is no longer duff and battery checks out OK.
Where for me it all went wrong was the emergency mechanical key usage. I was expecting some reaction from the car door locks when I inserted and turned the key. WRONG.
Firstly the manual is wrong. It suggests an anti-clockwise key turn. For me it was clockwise. Also a rather null, dead, etc. operation and feel, almost like you are forcing something that was never there.
In addition, and this is the killer, having had no obvious response from the emergency open operation when you get home and play you find that you have to remove the key, drop the door handle fully home and THEN, and only then, lift the handle again.
I initially thought that because I had set the deadlocks that this was fully locking me out. WRONG!
I strongly recommend all you Croma owners go and play at "emergency key entry" so that if you ever need to do it for real you know what to expect and how to do it properly.
NOTE! On entry the car alarm will go off! I've cancelled this with the remote to not upset the neighbours. I'm hoping / guessing that once you are in the car, with the alarm going off, that inserting the fob/key into the console and turning the ignition on will cancel the alarm. Next time I'm in a remote area/car park I'll check this out (unless someone beats me to it).
Zimples!
