My alternator belt started squealing on first starting a few months ago, only on wet mornings. It's since gradually got squealier, to the point now that it squeals constantly until the engine is hot when it usually gets dry enough to grip.
I've had a look under the bonnet but it looks to be in a very enclosed location. I have found the correct part number for a replacement belt, but haven't ordered it yet.
Is this a garage or DIY job? (for someone with common sense, but not much car repair experience) I've had a hunt around the forum, but can only find info on replacing the alternator itself.
Other questions...
Should the belt be replaced instead of tightened? I would guess so, as squealing means stretching therefore weakening.
Is replacing the belt more involved than tightening the existing one?
Is this likely to be a symptom of a more serious problem, i.e. the alternator stiffening up before failing?
Thanks all as ever...
P.S. It's a 150BHP 1.9 Diesel. I think the part no for the belt is 6PK1413.
Other questions...
