Old 21-02-2008   #1
New Croma - acceleration problem
My Croma (year and a half old) has been in the garage for a week now. When I accelerated, the car would only move very slowly and after about 8 - 10 seconds it would hit the correct speed. To get out of my road, you go up a hill. Last week it wouldn't get up the hill! After trying a few times it eventually made it.
The Fiat garage said it was the engine control unit and ordered that part. Today, they said it's not this part and cancelled the order. It's something else and they've ordered that part now. Sorry - I can't remember what this part is.
Anyone else had this? The problem I have is that they don't know how long this part will take to arrive.
swebb is offline Reply With Quote Quote
Old 21-02-2008   #2
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: New Croma - acceleration problem
what engine you got?
Old 23-02-2008   #3
It's 1.9 JTD 150 bhp.
Old 23-02-2008   #4
Forum Moderator
T14086's Avatar
T14086 has donated!
was it a EGR valve,swirl actuator or airflow meter they ordered?
Old 28-02-2008   #5
I'm not sure... whatever it was, it didn't work (part fitted today). They are now talking to Fiat to see what else they can find out. At the moment, they are at a loss.
Old 17-06-2008   #6
The orginal 'Old Grumpy'
Radlet6's Avatar
Radlet6 has donated!
Quote Originally Posted by swebb View Post
Hi Swebb
Can you tell me did they mange to fix this problem? Mine does the same, but not as badly. I also have the problem where every so often I get a message on start up saying that the ESP is unavailable with a yellow triangle warning light. Everything goes back to normal after a few hundred yards, except the reluctance to pull away. I notice that you are also concerned about the fuel consumption on your car, as am I on mine.
They have replaced the control unit on mine laready, to no avail.
AS part of the Government's new austerity measures, the light at the end of the tunnel has been turned off indefinitely.
Radlet6 is offline Reply With Quote Quote
Old 18-06-2008   #7
Livefast123 has donated!
Hi Guys
MY JTD 130 wouldn't do over 60 and couldn't even overtake trucks on a motorway hill!!!
What kind of milages have your cars done and what type of driving do they do ie motorway, oap etc
In my experience the causes of no power in JTD engines are as followed
1.MAF (air flow) sensor faulty - to test disconnect the plug to sensor, this puts ECU into default mode and you should see an improvement.
2.EGR valve blocked/Jammed - No power low down - Easy 5 minute job to remove and clean in some carb cleaner. Also check EGR/Inlet vent pipe for carbon build up.
3.Fly by wire throttle has a bad connection on the multiplug - the plug is on top of the throttle.
4.Fuel filter/Air filter badly blocked
5.Turbo/Intercooler hoses split (usually underneath)
6.ECU failure.........very very very rare. Caused by EGR being faulty for long period of time that messes up the MAS sensor then the ECU.
Livefast123 is offline Reply With Quote Quote
Old 26-02-2009   #8
nallen132 has donated!
A week into ownership and my car is exhibiting this feature quit scary, when you press the accelerator the car just moves very slowly revs increase very slowly no warning lights on the dash, then suddenly the car works normally.
first did it yesterday from a roundabout, then again on the way home from work just pulling out of the car park, seems to be when the car is cold..
ever get a fix for this?
nallen132 is offline Reply With Quote Quote
Old 26-02-2009   #9
zombie nation
Hellcat's Avatar
Trader Rating: 3
Hellcat has donated!
Guess who's did the very same thing this morning?
Drives: Fiat Multipla Eleganza , Owns: Alfa Romeo 159 2.4JTDm
Hellcat is offline Reply With Quote Quote
Old 26-02-2009   #10
nice to know its happening elsewhere (not), looks as if it could be a common fault, mines only done 34k and is just three years old..
will try these from above:
Old 26-02-2009   #11
Radlet6's Avatar
Mine is now sorted (see post of 17.06.08 above) - but was related to a host of other problems (ESP warning light, engine management light, air bag light, auto transmission light - complete malfunction of all systems stranding my partner)
Old 27-02-2009   #12
I may arrange for mine to go into a dealership\specialist to have the computer codes read.. see what comes out they may even know about the issue.
Also the Humming sound, that I think is a feature seems to be getting worse, or I am becoming more aware of it. may get that checked as well.
Old 27-02-2009   #13
been doing a bit research on here and other www places looks as if the EGR valve maybe the cause as it can stick marginally open, FIAT have now redesigned the EGR valve to prevent this happening. Although it is not subject to a recall..
anyone else come across this...
Old 01-03-2009   #14
Just a quick update the lack of acceleration has not reoccurred, fingers crossed...
Old 02-03-2009   #15
Curse of the were-rabbit
Bunny's Avatar
Bunny has donated!
Mine does it about once a week or so. I thought it would happen everyday, but no, just when i think the problem has corrected itself, it happens again
Mine: Croma 150 Mjet. His: Marea weekend
Bunny is offline Reply With Quote Quote
(G) Can Anybody Punto be THIS BAD!!! Fire.... justindublin Punto (Mk2/2b) 8 02-02-2007 21:18
(G) Punto MK1 Sporting Injection problem binarypunto Punto (Mk1) 2 29-11-2006 20:36
(T) Punto (second version) Dualdrive problem andre79ge Punto (Mk2/2b) 2 10-02-2005 22:43
(G) Mid-throttle injection problem in Lancia Y10 FatNote Panda (Classic) 26 30-07-2004 18:58
(T) 98 Punto 60sx acceleration problem barachello2000 Punto (Mk1) 9 30-07-2004 13:30
