[*]ALL DATA IS FOR A CINQ BUT SHOULD APPLY TO SEI'S WITH THE EXCEPTION OF MPI INJECTION COMPONENTS
- OHV relates to the 899cc engine.
- OHC relates to the 1108cc engine
Fluids:
- OIL:
- Multigrade engine oil, viscosity SAE 15W/40to API SG and/or CCMC-G4
- (plenty use 10W/40 in cinqs/sei's though)
Coolant:
- Ethylene glycol based antifreeze
Manual transmission:
- SAE 80 W EP gear oil to API GL4 and or MIL-L-2105
Braking system:
- Hydraulic fluid DOT 4 minimum
Tyre pressures
- Normal load
- 145-70-13
- Front & rear
- 2.0 bars (29psi)
- 165-55-13
- Front & rear
- 2.1 bars (30psi)
- Full load
- All models 2.2 bars (32 psi)
Capacities
- Engine oil inc filter OHV= 3.75 litres OHC=3.47 litres
- Cooling system OHV=4.8 litres OHC=4.0litres
- Transmission OHV/OHC=2.4 litres
- Washer fluid reservoir OHC/OHV=1.8 litres
- Fuel tank OHC/OHV= 35 litres
Engine
Oil filter type
- OHV champion C135
- OHC champion F107
- OHC valve clearance
- Inlet 0.40 +/- 0.05mm
- Exhaust 0.50 +/- 0.05mm
Fuel system
Air filter
- OHV champion U521
- OHC champion U647
- Fuel filter champion L201
- Engine idle speed
- OHV 850 +/- 50RPM
- OHC 900 +/- 50RPM
Exhaust gas CO content @ tailpipe
- OHV < 0.50%
- OHC < 0.35%
Ignition system
Spark plugs
- OHV champion RN9YCC 0.8mm electrode gap
- OHC champion RN9YCC 0.9mm electrode gap
Clutch
Pedal travel
- OHC(sporting) models 120 +/- 5mm
- OHV models 110 +/- 5mm
Brakes
Friction material minimum thickness
- Front pads 1.5mm
- Rear shoes 1.5mm
- Torque wrench settings
- Alternator securing bolts 49nm/36lb/ft
- Exhaust manifold
- OHV 20nm/15lb/ft
- OHC 28nm/21lb/ft
- Exhaust front pipe to manifold 18nm/13lb/ft
- Inlet manifold
- OHV 20nm/15lb/ft
- OHC 28nm/21lb/ft
- Road wheel bolts 86nm/63lb/ft
- Spark plugs 27nm/20lb/ft
- Transmission filler/level plug 25nm/18lb/ft
- Transmission drain plug 45nm/33lb/ft
OHV engine specs and torques
- Engine code 1170 A1.046
- Capacity 899cc
- Nominal bore 65.0mm
- Stroke 67.7mm
- Compression ratio 8.8 : 1
- Max power 29KW @ 5500RPM
- Max torque 65NM @ 3000RPM
- Firing order
- 1-3-4-2
- No 1 located at timing chain side of engine
Torque settings
- Camshaft sprocket bolts 45nm/33lb/ft
- Crankshaft pulley bolt 50nm/37lb/ft
- Crankshaft pulley bolt 100nm/74lb/ft
- Cylinder head bolts
- Stage 1 30nm/22lb/ft
- Stage 2 angle tighten 90o
- Stage 3 angle tighten another 90o
- Flywheel 45nm/33lb/ft
- Flywheel lower cover bolts 10nm/7lb/ft
- Front left hand engine mounting bracket to transmission 25nm/18lb/ft
- Front left hand engine mounting through bolt to nut 50nm/37lb/ft
- Front left hand engine mounting flange to bodyshell 25nm/18lb/ft
- Rear engine mounting bracket to diff case (M12 bolts) 85nm/63lb/ft
- Rear engine mounting bracket to diff case (M10 bolts) 70nm/52lb/ft
- Rear engine mounting flange to bodyshell 25nm/18lb/ft
- Rear engine mounting through bolt to nut 50nm/37lb/ft
- Right hand engine mounting, through bolt to night 50nm/37lb/ft
- Right hand engine mounting, flange to bodyshell 25nm/18lb/ft
- Rocker cover 8nm/6lb/ft
- Rocker shaft pedestal nuts 40nm/30lb/ft
- Sump 10nm/7lb/ft
- Timing chain casing bolts 8nm/6lb/ft
- Valve seat angle 45o 0’ +/- 5’
- Valve guide to bore in cylinder head
- Inlet & exhaust 0.033 to 0.080mm (interference fit)
- Valves
- Valve stem diameter 6.982 to 7000mm
- Valve face angle 45o 30’ +/-5’
- Valve face width 2.0mm
- Valve stem to guide clearance 0.022 to 0.058mm
Rocker gear
- Rocker shaft diameter 14.978
- Rocker shaft to rocker arm clearance 0.020 to 0.052mm
- Rocker shaft to support pedestal clearance 0.02 to 0.05mm
- Hydraulic tappet diameter 11.94 to 11.99mm
- Rocker arm to hydraulic tappet clearance 0.010 to 0.083mm
Camshaft
- Camshaft journal diameter
- No1.journal 30.975 to 31.000mm
- No 2.journal 43.348 to 43.373mm
- No.3 journal 37.975 to 38.000mm
- No1.journal 0.026 to 0.071mm
- No 2.journal 0.031 to 0.076mm
- No.3 journal 0.025 to 0.075mm
Cylinder block
- Bore diameter 65.000 to 65.050mm
- Undersizes: increments of 0.010mm
- Cam follower diameter 13.982 to 14.000mm
- Cam follower to bore clearance 0.010 to 0.046mm
Pistons and piston rings
- Piston diameter
- Grade A 64.95 to 64.96mm
- Grade B 64.97 to 64.98mm
- Grade C 64.99 to 65mm
- Piston to bore clearance
- Up to engine no. 8600000 0.011 to 0.039mm
- From engine no. 8600000 0.05 to 0.07mm
- Maximum difference in piston weight +/- 5.0g
- Gudgeon pin diameter 19.974 to 19.978mm
- Gudgeon pin to piston clearance 0.008 to 0.017mm
- Piston ring to ring wall clearance 0.008 to 0.017mm
- Top compression ring 0.045 to 0.077mm
- 2nd compression ring 0.045 to 0.080mm
- Oil control ring 0.020 to 0.052mm
- Piston ring end gap
- Top compression ring 0.025 to 0.045mm
- 2nd compression ring 0.02 to 0.04mm
- Oil control ring 0.020 to 0.045mm
- Gudgeon pin to small end clearance 0.014 to 0.038mm(interference fit)
Crankshaft
- Main bearing journal diameters
- Grade 1 50.795 to 50.805mm
- Grade 2 50.785 to 50.795mm
- Crankpin journal diameters 39.985 to 40.005mm
- Main bearing running clearance 0.026 to 0.061mm
- Big end bearing clearance 0.026 to 0.074mm
- Crankshaft endfloat 0.06 to 0.26mm
- Big end bolts/nuts 41nm/30lb/ft
- Crankshaft rear oil seal housing bolts 10nm/7lb/ft
- Main bearing cap bolts 69nm/51lb/ft
OHC engine specs and torques
- Engine code 176.B2.000
- Capacity 1108cc
- Nominal bore 70.0mm
- Stroke 72.0mm
- Compression ratio 9:6:1
- Max power output 40KW@5500 RPM
- Max torque 86NM @3250RPM
- Firing order 1-3-4-2
- No1 cylinder located at timing belt end of engine
- inlet 0.40 +/-0.05mm
Lubrication system
- Oil pump is bi rotor driven from front of crankshaft
- Outer rotor to housing clearance 0.080 to 0.186mm
- Axial clearance 0.025 to 0.056mm
- Camshaft caps:
- M8 x 1.25 20nm/15lb/ft
- M8 10nm/7lb/ft
- Camshaft cover 8nm/6lb/ft
- Camshaft sprocket 70nm/52lb/ft
- Cylinder head
- Engine mounting bolt
- M10x1.25 56nm/44lb/ft
- M8 25nm/18lb/ft
- Engine mounting nut (M10x1.25) 59nm/44lb/ft
- Flywheel 44nm/32lb/ft
- Sump 10nm/7lb/ft
- Timing belt tensioner 28nm/21lb/ft
Cylinder head
- Camshaft bearing diameters
- No.1. 24.045 to 27.070mm
- No.2. 23.545 to 23.570mm
- No.3. 24.045 to 24.070mm
- Valve seat angle 45o 30’ +/-5’
- Valve follower (tappet) running clearance in head 0.005 to 0.050mm
Valves
- Valve stem diameter 6.982 to 7.000mm
- Valve face angle 45o 30’ +/- 5’
- Valve follower (tappet) shim sizes 3.2 to 4.7mm in increments of 0.05mm
Camshaft
- Camshaft bearing running clearance 0.03 to 0.07mm
- Camshaft endfloat 0.07 to 0.25mm
Cylinder block
- Bore diameter 70.000 to 70.030mm
- Undersizes increments of 0.010mm
- Piston diameter
- Grade A 69.96 to 69.97
- Grade B 69.97 to 69.98
- Grade C 69.98 to 69.99
- Piston to bore clearance 0.03 to 0.05mm
- Gudgeon pin diameter 17.970 to 17.974mm
- Gudgeon pin to piston clearance 0.008 to 0.016mm
- Top compression ring 0.04 to 0.08mm
- 2nd compression ring 0.02 to 0.055mm
- Oil control ring 0.2 to 0.45mm
- Top compression ring 0.25 to 0.45mm
- 2nd compression ring 0.25 to 0.45mm
Connecting rods
- Gudgeon pin to small end clearance 0.014 to 0.035mm(interference fit)
Crankshaft
- Grade 1 43.994 to 44.000mm
- Grade 2 43.998 to 43.994mm
- Grade 3 43.982 to 43.998mm
- Crankpin journal diameters 37.990 to 38.008mm
- Main bearing running clearance 0.025 to 0.047mm
- Big end bearing running clearance 0.024 to 0.060mm
- Crankshaft endfloat 0.055 to 0.265mm
- Main bearing cap:
- Stage 1 40nm/30lb/ft
- Stage 2 angle tighten to 90o
Cooling system
- Expansion tank pressure release cap opening pressure 0.98 BAR
Thermostat
- Starts to open 85 to 89oC
- Fully open 96 to 100oC
Electric cooling fan
- Cut in temp 90 to 94oC
- Cut out temp 85 to 89oC
- Coolant pump
- Securing bolts (OHC) 8nm/6lb/ft
- Securing nuts(OHC) 10nm/7lb/ft
- Rear cover bolts(OHV) 7nm/5lb/ft
- System type (OHV & OHC) weber marelli single point injection/ignition system
- Fuel system
- Fuel pump type: electric immersed in tank
- Delivery rate: 110 litres/hour minimum
- Regulated fuel pressure
- OHV 1.1 +/- 0.2 BAR
- OHC 1.0 +/- 0.2 BAR
- Pressure relief valve opens @ 2.6 BAR
- Coolant temp resistance (approx)
- @ 0oC 10Kohms
- @ 20oC 5Kohms
- @60oC 10Kohms
- Crankshaft TDC sensor resistance @ 20oC 575 to 720 ohms
- TDC sensor to reluctor wheel clearance 0.5 to 1.5mm
- Injector duration @ idle 1.5ms
- Lambda sensor heater resistance @ 20oC 2.5 to 4.5 ohms
- Min 95 RON unleaded fuel
- Coolant temp sensor 2.5nm/1.8lb/ft
- Exhaust downpipe bracket (OHC) 24nm/18lb/ft
- Exhaust downpipe to manifold 18nm/13lb/ft
- Exhaust manifold 18nm/13lb/ft
- Exhaust system clamp bolts/nuts 24nm/18lb/ft
- Fuel filter collar nut 5nm/4lb/ft
- Fuel tank 28nm/21lb/ft
- Idle control steeper motor 4nm/3lb/ft
- Inlet manifold(OHC) 27nm/20lb/ft
- Lambda sensor 50nm/37lb/ft
- Throttle body to manifold 7nm/5lb/ft
- Throttle potentiometer 2.5nm/1.8lb/ft
Starting & charging systems
- 12volt negative earth system
- Starter motor magneti marelli (pre engaged)
- Output 0.8KW
- Solenoid pull in coil resistance 0.3 ohms
- Solenoid hold in coil resistance 1.2 to 1.3 ohms
Battery
- Capacity 40 A-hr
- Charge condition
- Poor 12.5V
- Normal 12.6V
- Good 12.7V
Maximum current
- OHV 200A
- OHC 150A
Alternator
- Type magneti marelli
- Maximum current
- OHC 65A
- OHV 55A
- Cut in speed
- OHC 1050 to 1150 RPM
- OHV 950 to 1050 RPM
- Field winding resistence
- OHC 2.6 to 2.8 ohms
- OHV 3.0 to 3.2 ohms
- Alternator mounting bolts 49nm/36lb/ft
- Battery terminal clamp bolts 4nm/3lb/ft
- Wheel bolts 86nm/63lb/ft
- Starter mounting bolts 45nm/33lb/ft
Ignition system
- System type: weber-marelli static(distributorless) “wasted” spark system controlled by ECU
- No1 @ timing belt end
- Ignition timing
- OHC 8o +/- 3o @ 900RPM
- OHV 11o +/- 3o @ 850RPM
- Ignition coil winding resistance @ 20oC
- Primary 0.5 to 0.6 ohms
- Secondary 6.6 to 8.1 ohms
Clutch
- Single dry plate with diaphragm spring.cable operated
- Friction plate diameter
- OHV 170.0mm
- OHC 181.5mm
torque wrench settings
- Pressure plate retaining bolts 10nm/7lb/ft
Manual transmission
- Transverse mounted front wheel drive layout with integral transaxle differential/final drive.
- Designation:
- OHV C.501.5.10
- OHC C.514.5.10
Driveshafts
Solid steel shafts with inner & outer constant velocity joints(CV)
Both outer joints are of the ball and cage types.
The inners are tripod types
- Front hub nut 240nm/177lb/ft
- Lower arm balljoint nut 49nm/36lb/ft
- Track rod end and ball joint to hub carrier nut 34nm/25lb/ft
Front brakes
- Disc diameter 240.0mm
- Disc thickness
- New 10.8 to 11.1mm
- Min thickness after refinishing 9.55mm
- Minimum wear limit 9.2mm
- Maximum disc runout 0.15mm
- Brake pad minimum thickness 1.5mm
Rear brakes
- Drum internal diameter
- New 185.24 to 185.53mm
- Max diameter after refinishing 186.33mm
- Minimum (wear limit) 186.83mm
- Brake shoe friction material min thickness 1.5mm
- Brake disc securing bolt 12nm/9lb/ft
- Brake hose to front caliper union nut 15nm/11lb/ft
- Brake pipe union nuts:
- M10 11nm/8lb/ft
- M12 18nm/13lb/ft
- Front calliper mounting bracket bolts 53nm/39lb/ft
- Handbrake lever securing nuts 15nm/11lb/ft
- Master cylinder securing nuts 20nm/15lb/ft
- Rear brake back plate securing nuts 20nm/15lb/ft
- Rear brake drum securing bolt 12nm/8lb/ft
- Rear brake pressure regulating valve bolt/nut 24nm/18lb/ft
- Rear wheel cylinder securing bolts 10nm/7lb/ft
- Vacuum servo mounting bolts 25nm/18lb/ft
Wheel alignment and steering angles
(Measured with correct tyre pressures and 5 litres of fuel)
- Front wheel castor:
- Non Sporting 1o 40’ +/- 30’
- Sporting 1o 36’ +/- 30’
- Front wheel camber:
- Non Sporting 0o 30’+/- 30’
- Sporting 0o 5’ +/- 30’
- Front wheel toe setting 0 +/- 1.0mm toe in
- Rear wheel camber:
- Non sporting 0o 30’ +/- 30’
- Sporting 0o 1’ +/- 30’
- Rear wheel toe setting:
- Non sporting 0 +/- 3mm toe in
- Sporting 1.0 +/- 3mm toe out
Front suspension
- Lower arm front mounting nut 88nm/65lb/ft
- Lower arm rear mounting bolts 88nm/65lb/ft
- Suspension strut piston rod nut 88nm/65lb/ft
- Suspension strut to body nuts 25nm/18lb/ft
- Suspension strut to hub carrier nuts 108nm/78lb/ft
Rear suspension
- Rear hub nut 216nm/159lb/ft
- Rear suspension crossmember mounting bolts 88nm/65lb/ft
- Shock absorber securing bolts 49nm/36lb/ft
- Trailing arm pivot nuts 88nm/65lb/ft
Steering
- Lower steering column securing bolts 25nm/18lb/ft
- Steering column/intermediate shaft pinch bolt nut 20nm/15lb/ft
- Steering gear securing bolts 49nm/36lb/ft
- Steering wheel nut 50nm/37lb/ft
- Track rod end balljoint to hub carrier nut 34nm/25lb/ft
