Old 13-06-2006   #1
Va Va Vroom
Tweedbean's Avatar
Tweedbean has donated!
Engine Problems Fast response needed
Hi selling my car when suddenly it starts to overheat constantly. What it does is after i drive it for a couple of miles, it throws the contents of the water coolant tank out the bottom of the car?
Just had a new radiator and fan switch but it is still doing it, any ideas?
James B
Tweedbean is offline Reply With Quote Quote
Old 13-06-2006   #2
Formerly mog1571
Luke M's Avatar
Trader Rating: 2
Luke M has donated!
Re: Engine Problems Fast response needed
hose leaking or fallen off?
Previous 2005-2007 - 2001 Capri blue seicento SX
Current 57 plate GP active sport, action red, Sporting front fogs, JBL Sub and amp.
Luke M is offline Reply With Quote Quote
Old 13-06-2006   #3
Status: DEFCON Grumpy
custard's Avatar
Trader Rating: 1
custard has donated!
if its just had work done then look to those areas 1st
Old 13-06-2006   #4
Ireland
Sounds like what happened to my sei . It ended up being the water pump leaking !!!
isterica is offline Reply With Quote Quote
Old 13-06-2006   #5
Va Va Vroom
Tweedbean's Avatar
had the radiator done yesterday because it had a leak. had the problem last friday so took it in and they changed this and checked the head gasket. water is coming from under the cap on the tank which they also replaced the cap so it not that either
Old 13-06-2006   #6
I hold up buses
balidey's Avatar
Trader Rating: 1
balidey has donated!
Check near the thermostat. The water in the engine just goes round the engine until it gets hot, then the thermostat opens and passes through the radiator, so if it does it after a while then it sounds like its after that.
I hold up buses
balidey is offline Reply With Quote Quote
Old 13-06-2006   #7
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
They did bleed the cooling system properly, yes?
D
(G) Fiat Uno, Engine temperature problems pikkumies Uno 6 17-11-2016 15:48
(T) Major Problems, Help needed!!! Chris0288 Punto (Mk2/2b) 12 25-12-2006 13:31
oil - question for GC Hellcat Lets Talk FIAT 47 17-01-2006 13:54
(T) supporting the engine.. help needed asap! arc Cinquecento / Seicento 7 27-03-2005 21:53
