Technical poor radio reception
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
could be a number of things, rubbish HU for example, the poor weather as well could be a factor.
When i used to have a bit of a poor reception, i adjusted my aerial to a more vertical stance (y)
Could be a loose aerial, HU problem, aerial problem, loads of things..............
replaced the head unit with the old sony from my Alfa, no better..
moved up the ariel to be more vertical, no better..
will try cleaning the ariel base now.. is it easy to get at/out?
IIRC I just unscrewed the aerial and then theres either a couple more screws in ther or you can just take it apart, not too sure as it was a while back. But its easy enough to do.
Is the aerial lead touching the barbehind the dash at all? I tie wrapped mines to this bar and radio reception went crap but it was fine before.
Liam
Liam
it was tie rapped to that bar but i undid it and fed it down the sill trim and back.. but no better
