Badger_Benji
Member
1242 is now fitted, but there is a major problem, the battery wasnt disconnected, so thought we should be ok with the immobilizer as I dont have the red key, well it seems i have broken another egg whilst making my omellette.
Got the engine all fitted, fluids filled, got in, put in blue key, turned the key, code light stays light, the engine turns over, but no start, and the code light never goes off, after a couple of cranks, the engine fault light also lights
Im guessing I either need a red key, or a chip to bypass the immobilizer. But the engine fault light coming on does that indicate there is a problem somewhere else, I have a suspicion about the crank position sensor as the wire looks chaffed. So am replacing that as well.
All suggestions as to what a good plan of attack or words of consolation, would be greatly received.
On a positive note, the csc marmite manifold complete with machined spacer is all fitted, and I do have pictures, just ran out of time last night to get them off the camera.
