mckrob
Member
Right, the plan is to run 2 red leds tubes, hidden away under the dash in each front footwell. I want to rig it up on the same system as the interior light runs on, so when the doors open, you get a nice red glow at night.
The LED tubes themselves are PC tubes, meaning its a molex connector, but i'm assuming i can just butcher that down to a red and black wire. Is it a simple case of joining it up to the interior light, or will running 2 lights from this simply dim all 3 lights? And would i have to change the fuse so to compensate for the extra power being used by the light?
Obviously, just sticking the wires straight on the battery and rigged up with a switch would be the easist route, but then i want it to light up as the doors open. Any suggestions?
