Smilermark
- Jan 2, 2018
- 2
- 1
Hello
So I bought my son his first car 2001 Sei 1.1 MPI with 101K miles.
Needed some work but was running fine. Fitted new Fuel Tank, Shocks, Brake Pipes, Rear Wiper Motor and some welding and it's through the MOT. The guides on this Forum are fantastic.
Then.....
The car sat for a couple of months whilst the tank and pipes etc were done. On initial start up there was a loud whining that got better after 10 mins.
The car did use some coolant in the following weeks and the heater didn't blow hot air. But my son was happily driving it around everyday.
I tried to bleed the cooling system of air, in an effort to get the heater to work. The bleed pipe behind the headlight flowed OK but not the heater one - it only did very slightly when the engine was reved.
Then son drove the car yesterday for 15 miles and then sat in traffic for 20 mins. The coolant all blew out through the cap and he pulled in.
Refilled coolant after it had cooled down. Engine starts and runs but tick over is lumpy, engine light comes on when driving a short distance and the coolant has oil in it. The engine fan is coming on.
So I'm guessing it's new water pump and belts, replacement head gasket and head skim???
Would anyone with more knowledge than me (most) on here like to give me their thoughts. I'm guessing the water pump was on it's way out and I should have got it replaced when I first heard it whining.
Then.....
