Old 31-10-2003   #1
flat spot!!!!!
[}:)]on my cinq sporting (yellow!!!!!) i have a k+n 57i and a centre exit 3" sportex exhaust apart from that the engine is standard. now and even before i fitted the above i sometimes get a small flat spot while accelerating? not all the time but usually when the engine is cold sometimes when its hot?????? really puzzling me. any ideas ????
WHEN THIS BABY HIT'S 88...YOUR GONNA SEE SOME SERIOUS s**t!
fimmo is offline Reply With Quote Quote
Old 31-10-2003   #2
Make sure you have not damage the oxygen sensor.. It will probaly be that :):):)
FiatExpert is offline Reply With Quote Quote
Old 31-10-2003   #3
Became old and sensible
MrDerv's Avatar
MrDerv has donated!
there's a flat spot around 3k revs but the k&n should iron that problem out. First things first, Replace the spark plugs with Bosch Super4's and replace the ignition leads. see how that goes, if money isn't a problem, go for Magnecor Leads.
If that don't fix it, could be the Lambda sensor which are about 60 to replace. It's a much needed item and VERY delicate so if you remove it, DON'T drop it, or it's a trip to fiat for a replacement.
Other symptoms may include, blocked fuel filter, blocked injector and incorrect fuel pressure.
Hope that helps
www.brickfoot.co.uk is here!!
Coming soon: Cinq lower than a Prostitute's knickers!
MrDerv is offline Reply With Quote Quote
Old 01-11-2003   #4
Sorry, hate to be a to$$er, but bosch plugs dont really agree with fiat engines. We fitted loads on services and most came back within 3 or 4 weeks with missing and backfiring problems. Replaced the plugs with NGK's and they run fine after that. [8)]
Pete
K&N Induction Kit On A Panda?? Never!!!
pete1nlancs is offline Reply With Quote Quote
Old 01-11-2003   #5
I have Champion EON and have noticed no difference between them and my Fiat 1's except price and the life span 36,000 or 3 years on the Champions :)
http://jonesycinquecento.4t.com
Jonna83 is offline Reply With Quote Quote
Old 01-11-2003   #6
MrDerv's Avatar
MrDerv has donated!
Are your EON plugs 1 point or 2? Take it you posted that reply after work?;)
Old 01-11-2003   #7
Im not sure to be honest I can't remember :pand yes i'd been in for about half an hour when i wrote that made good tips last nite which ment I cud buy a mike the burger van man bacon cheese burger :D
Old 04-11-2003   #8
When mine is cold there is a bit of a flat spot around 2.5k, only for a few minutes when first started though. Dont notice it anymore though, I start the engine in a morning and then have a fag. By the time I've finished the fag the engine and car is warm and mist free inside:D!
Very technical instructions on removing cold flat spot (only for advanced mechanics):
1, start engine
2, have fag
3, when fag is finished, get in car and drive off
Wanted: Car with no rattles
Sando is offline Reply With Quote Quote
Old 04-11-2003   #9
Don't smoke you'll die.
Cinq owner, Punto on the way!
96 N Cinqo Sporting
Rosso Sporting Red
57k
elchinko is offline Reply With Quote Quote
Old 04-11-2003   #10
we all die, may as well enjoy life while I can. Quit for two years then I started again :I
Old 04-11-2003   #11
MrDerv's Avatar
MrDerv has donated!
You could get hit by a bus tomorrow! That's the warning on my fag packet anyway!
Old 04-11-2003   #12
My car could rattle itself to bits on the way home and my head could be pierced by a stray part of bonnet.
Old 04-11-2003   #13
Principality Retained :)
Trader Rating: 3
arseofbox has donated!
It cant be that bad....imagine 5 cd cases in each door pocket and a 900cc engine at redline at 90mph....:D
Arse
Feel the magic........the magic is coming...Watch him starve himself to death!!Hehehehe
arseofbox is offline Reply With Quote Quote
Old 05-11-2003   #14
HP
I was only doing 80...
HP's Avatar
HP has donated!
<blockquote id="quote">[size=1] face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by pete1nlancs
Pete
<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Have to say I think Super 4's work well on cinq/sei engines.
Pete.
Cinq sporting 1242cc
Cinqs&Seis Yahoo group
Clubcento
HP is offline Reply With Quote Quote
Old 05-11-2003   #15
i've replaced the plugs,almost threaded one of them cause of lack of access! checked sensors etc everything seems to be ok? the flat spot is still there but only every now and then???? and yes it is about 2.5 0r 3 thousand revs? seems common???
Marea Spot the differece polecat Members Motors 20 25-04-2004 00:41
(G) Mystery of the 3krpm flat spot solved? mckrob Cinquecento / Seicento 18 11-03-2004 04:41
(T) Flat Battery msmbus Stilo 3 21-02-2004 02:35
(T) cured my 3k flat spot!! fimmo Cinquecento / Seicento 7 16-01-2004 05:41
(T) Flat battery chris56 Stilo 1 24-11-2003 20:53
