FIAT Auto Specialist Team
Thread Tools
Old 20-11-2013   #1
Grumpy old man
unclebloodyfester's Avatar
unclebloodyfester has donated!
Rear lights - no tail lights but working brake lights
had a spare set of LED bulbs kicking around so threw them in the brake / tail lights and all was well at first as one of mine had blown - old bulb tbh.
But now i get some funky behaviour
Now when the boot is closed I have working brake lights but the side lights stay off.
When you open the boot both side and brake lights work.
When the boot is closed only the centre high level brake light illuminates until you hit the brake pedal at which point all the brake lights come on but still no rear sidelights.
Is this just a weird fault with LED lights and incorrect resistance being thrown into the earth circuit? I presume that going back to standard filament bulbs will cure the 'fault'?
unclebloodyfester is offline Reply With Quote Quote
Old 20-11-2013   #2
Re: Rear lights - no tail lights but working brake lights
Try only using a pair of LEDs only for sides and then a pair only for stop. An individual LED only lights with one polarity but replacement 'bulbs' may have an additional bridge circuit to work both ways in any auto.
You would need the fiat circuit and LED circuit diagram to work out what is 'wrong'.
standard Sei Sporting except for
colour matched ice scraper, screw driver,
& steering wheel lock i.e yellow car
spare alternator belt, clutch cable & bulb set, 2x overalls
Pep0 is offline Reply With Quote Quote
Old 20-11-2013   #3
Grumpy old man
Fixed - it was the LED bulbs causing the short - i suspect the pins on the base don't quite line up and were touching things they shouldn't be - either way .... new filament bulbs fitted and all is well.
Thumbs up to Halfords for letting me use their awning to fit them under
Thread Tools
(S) Abarth Tail lights / Rear lights GrandeBen Grande Punto 28 20-12-2017 12:12
(T) Side lights and tail lights not working - fuse? jiminwatford Cinquecento / Seicento 1 31-12-2009 20:01
(T) Speedo, Brake Lights & Reverse Lights Not Working cchheessyy Cinquecento / Seicento 6 07-05-2009 21:48
(T) Cinq Sporting Electrical Problem - Brake lights/rear lights namb Cinquecento / Seicento 3 20-02-2005 17:00
