Well i had quite a morning!
Left an hour early today to beat the traffic, started the car up 5 mins before i left to de-ice and set off.
I noticed immediately that the gears were very hard to get into but i put it down to the oil being cold. A couple of miles later and went to change into 5th and it wouldnt go in! Went for the other gears and the wouldnt go in either! So i managed to roll into a layby safely out of traffic.
I thought the inner boots may have split but there was no signs of spill when i looked. Luckily i had my tools in the car so i cracked off the fill plug to check the level and out came a pea green looking oil! It wasnt overfull. I walked to halfords with was 10 mins away and grbbed some 'cheap' 75-90 and a drain pan and changed out the oil.
After this managed to get to work no problem and on time! I only changed the oil at 72k in june and im now on 83k, could this be water? Would it be worth getting some higher quality oil back in?
I will upload a pic tonight of the oil that came out later
Just thought id share that with you guys
Chris
Chris
