![]() | #16 | ||
![]() | Re: Seicento radiator fan Second hand rad fans are a waste of time, as they are close to the end of life by now. As quoted, the op is looking for a rad FAN and not a radiator?
![]() | #17 | ||
Posts: 663 Thanks: 27 Trader Rating: 0 ![]() | Re: Seicento radiator fan
![]() | #18 |
Posts: 1,478 Thanks: 42 Trader Rating: 0 ![]() | Re: Seicento radiator fan Ebay has gazillions of aftermarket fans the right size which will more than likely do the job just fine. We have discussed this before, can't remember where. Problem is the mounting kits are a bit mickey mouse and require you to put cable tie like things through the rad. This IMO puts a lot more load on the radiator structure and its mountings than is ideal, also they are a bugger to get off afterwards without destroying the fixings. However if I was in a bind and short of mulla, and if I just needed my car running ASAP without stretching my budget, if it was my only alternative to preventing the inevitable head gasket failure caused by running the car without one. Would I fit one, damn right I would! Even better by one of these slim line fans and make your own mounting brackets job done. ![]()
__________________ ![]() Still here but normaly over there... Always late but worth the wait. ![]() |
![]() | #19 | ||
Posts: 731 Thanks: 13 Trader Rating: 4 ![]() | Re: Seicento radiator fan
![]() | #20 |
Posts: 1,478 Thanks: 42 Trader Rating: 0 ![]() | Re: Seicento radiator fan IIRC Ming and RallyCinq run the slimline ebay type fans with no issues? I fitted one to a custom motorbike, the quality was good I just didn't like the mounting system. It's still running 2 years later exposed to worse conditions than it would ever see on a car. ![]() How often does a fan actually kick in ? and for how long ? These also die on a regular basis through bearing failure, there are several threads about failed rad fans every month. Just like alternators and clutch cables it's a very common Cento problem, and something I wouldn't buy second hand personally.
![]() | #21 | ||
Posts: 16 Thanks: 0 Trader Rating: 0 ![]() | Re: Seicento radiator fan Hi Ouby and thanks for the two replies regarding cheap radiators. But.......it's not a radiator I'm after. My radiator is fine. My radiator fan has seized and cooked. Ebay sell new ones for £85 delivered. If I could get one for £35....yep, I'd be well pleased mate.
![]() | #22 | ||
Posts: 731 Thanks: 13 Trader Rating: 4 ![]() | Re: Seicento radiator fan If you want a 2nd hand one let me know........ or if you think that its not worth it, then no worries........ you pays yer money........ ![]()
![]() | #23 | ||
Posts: 16 Thanks: 0 Trader Rating: 0 ![]() | Re: Seicento radiator fan Thanks for all the replies guys...some good suggestions. I hadn't thought of fitting one of the universal fan kits. Apologies to Ouby as I replied to your post before I'd read page 2 ![]() Good news......I've had the offer of a new Sei MPI rad fan through this forum so hopefully I'll have it fitted next week. Then I can drive through town without having the heater on full blast and the windows open ![]() Just need to get a new Cat and pair of front Yokomama A359s for the MOT now ![]()
![]() | #24 | ||
Posts: 16 Thanks: 0 Trader Rating: 0 ![]() | Re: Seicento radiator fan I think I meant A539s...oops
![]() | #25 | ||
Posts: 731 Thanks: 13 Trader Rating: 4 ![]() | Re: Seicento radiator fan Im glad you got this sorted !! ![]() ![]()
![]() | #26 | ||
Posts: 663 Thanks: 27 Trader Rating: 0 ![]() | Re: Seicento radiator fan ![]() At least i will get an early night tonight.... 1:30am! -blast, blast, damn! ![]()
![]() | CamBanfield | Cinquecento / Seicento | 7 | 18-06-2012 23:46 |
![]() | dgable | Cinquecento / Seicento | 42 | 23-06-2010 00:12 |
![]() | doddsy | Cinquecento / Seicento | 8 | 24-02-2009 15:57 |
![]() | satty | Cinquecento / Seicento | 11 | 14-08-2005 13:30 |
