Old 04-06-2012   #1
Reverse gear gone
Heyy,
In the past my boyfriends always dealt with the car fixing it and what not as I am rather useless haha but his own car is being a drama queen and he can't seem to figure out what mines doing wrong.
A couple of weeks ago my reverse gear stopped working, I could push the gear stick down and pull it over but not slot it in but now I can even push the gear stick dow. It happened all of a sudden with no grinding or anything as warning. The rest of the gears are fine, no grinding or sticking as you'd normally see with a failing gear box? I was wondering if anybody has had the same issue or something similar and if so cause and how to fix ? Thank you x
Beca is offline Reply With Quote Quote
Old 04-06-2012   #2
Trader Rating: 5
fingers99 has donated!
Re: Reverse gear gone
Can't even push the lever down? Sounds to me that the mechanism inside the gearlever itself has failed, so that the detente can't be undone. (Usually if the cable has failed, first becomes difficult as well.)
Strip lever if you can, and investigate.
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 04-06-2012   #3
Trader Rating: 3
ycming has donated!
i take it this is the cinquecento.
Make sure the cable is clip onto the gearstick probably.
Ming
Wanted : Nothing at the moment
ycming is offline Reply With Quote Quote
Old 04-06-2012   #4
Thanks guys. Would the clip be near the top of the gear stick? Sorry to be a bit vague I just don't know much haha
Old 04-06-2012   #5
Trader Rating: 3
ycming has donated!
yeah unclip the gator, the cable should be firmly clipped onto the gear stick. is a quick check .
Ming
(T) Gear problem, 1st gear hard to engage and reverse grinds very loudly. help please ? mygrande Grande Punto 15 08-12-2012 11:40
(T) Sporting, Reverse gear stopped working... reverse inhibitor? Eiteews Cinquecento / Seicento 5 04-06-2012 21:30
Punto (Mk2/2b) reverse gear shaun2724 Newbie Central 2 20-02-2012 16:16
(T) No reverse gear UnoMia Uno 2 01-11-2011 20:05
