In the next 2 or 3 months I should be in a position to do a small run.
They'll be steel, plated, with separate steel woodruff keys, to 1.4 16v pattern (so folks using them on older engines will need a later cam pulley, belt and water pump).
No solid idea of price yet -- depends on size of run, as setting up is a pretty much fixed cost -- but under a hundred quid.
